Re: Do I need a High volume oil pump
[Re: Beep Beep]
#1201188
03/22/12 12:46 AM
03/22/12 12:46 AM
Posts: 43,244 Bend,OR USA
Cab_Burge
I am in the process of a 498 stroker build from a 400 block. I am running a street solid roller setup. Do I need a HV pump or is a stock replacement pump good enough? I am using a 6 quart hemi oil pan.
I have three stroker motors like your using, I used the high volume oil pump on all three with the stock 3/8 440-6pak pick up for that pan I did find out if I let the oil level get down to the add mark I would loose some, not all, oil pressure at the end of the quarter mile when I let off and applied the brakes, my car runs 130+ MPH in the quarter, no probblems in the 1/8 mile racing
[Re: Beep Beep]
#1201189
03/22/12 11:06 AM
03/22/12 11:06 AM
RapidRobert
loose clearances/oiling passage mods/high rpm would be where I'd use a hi vol.
[Re: jamesc]
#1201191
03/22/12 06:40 PM
03/22/12 06:40 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I tried the HV pump on my 71 RR years ago. I had the same problem of loosing pressure at the top end. Swapped for a HP and never had anymore problems..
I am truckless..
