New build- ticking lifters
#1201129
03/21/12 10:59 PM
03/21/12 10:59 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
With the exhaust now on the 360 Magnum I can hear what sounds like a couple of lifters ticking on the left bank. I thought at first it could be an exhaust leak but no leaks can be found. Remember this is a roller cam engine. Are there some things to try first to quiet them down? There is now about 30 miles of street driving on the engine.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: New build- ticking lifters
[Re: dfsmopars]
#1201134
03/22/12 02:42 PM
03/22/12 02:42 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Could be crap o worn our rockers, or shot lifters, are the lifters new?
Kasey
[Re: Moparnut426]
#1201135
03/22/12 10:59 PM
03/22/12 10:59 PM
dfsmopars
Kentucky
Kasey, The lifters are new from Hughes. I measured the original push rods and they were right on the correct factory length. The rockers were clean but of course they are used.
[Re: dfsmopars]
#1201137
03/22/12 11:13 PM
03/22/12 11:13 PM
Posts: 1,762 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
This may sound silly, but as you were assembling these, did you go through at least 2-3 cycles of crank rotation? I wonder if the pushords happen to be hitting the head in the head passege somehow?
I did have this happen...I knew the fit was tight, but thought it was good enough. Not quite...after the initial start-up, I pulled the covers to find a good/deep scuff mark on one of the pushrods...it was enough to give it a good clatter though.
[Re: dfsmopars]
#1201138
03/23/12 12:33 AM
03/23/12 12:33 AM
Posts: 3,688 Alexandria,La.
BigTerry
Alexandria,La.
so you can use magnum roller lift with stock LA rocket on LA engine???
[Re: BigTerry]
#1201139
03/23/12 07:08 AM
03/23/12 07:08 AM
dfsmopars
Kentucky
This is a '94 5.9 Magnum engine that came from the factory with a roller cam. There is no mixing and matching going on here. I do remember a couple of lifters that seemed to ride in their bores a little tighter than the others. I took Emory cloth and smoothed the corners at the top and bottom of the bores. Maybe it was not enough.
