Carburator date code question? #1200859
03/21/12 03:21 PM
03/21/12 03:21 PM
Ontario, Canada
B5Superbird Offline OP
Ontario, Canada
I found an old carter carb, and i'm wondering if it is dated correctly for my Superbird..
It's a Carter carb. Carb # 4738S Build date 2259 part number 54.
Is this properly coded for a 1970 Superbird 440 4bbl? B30 production date.
Re: Carburator date code question? [Re: B5Superbird] #1200860
03/21/12 04:10 PM
03/21/12 04:10 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
If it's the correct part number, I believe it would be considered an acceptable date code for your car since it precedes the SPD but it would also be considered a real early date.
Re: Carburator date code question? [Re: RoadRunnerJD] #1200861
03/21/12 04:21 PM
03/21/12 04:21 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
carburetor date codes varied tremendously. As long as it precedes your cars spd it's fine. A date only a week or few days before may be a little tight simply to alow some time for it to be shipped from the vendor to the production line.
Re: Carburator date code question? [Re: ScottSmith_Harms] #1200862
03/21/12 04:37 PM
03/21/12 04:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
John,
That's about two months earlier than the average,most birds are in the 280/290 range,guess it depends on how critical one wants to be as far as numbers.Most are stamped K9/L9,being October / November of 69.
Re: Carburator date code question? [Re: 62maxwgn] #1200863
03/21/12 04:38 PM
03/21/12 04:38 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
November
Re: Carburator date code question? [Re: B5Superbird] #1200864
03/21/12 04:43 PM
03/21/12 04:43 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
B30 is the SPD on all birds, Not thae actual SPD of your car.
