Carburator date code question?
#1200859
03/21/12 03:21 PM
03/21/12 03:21 PM
Posts: 119 Ontario, Canada
B5Superbird
Ontario, Canada
I found an old carter carb, and i'm wondering if it is dated correctly for my Superbird.. It's a Carter carb. Carb # 4738S Build date 2259 part number 54. Is this properly coded for a 1970 Superbird 440 4bbl? B30 production date. Thanks
Re: Carburator date code question?
[Re: ScottSmith_Harms]
#1200862
03/21/12 04:37 PM
03/21/12 04:37 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
If it's the correct part number, I believe it would be considered an acceptable date code for your car since it precedes the SPD but it would also be considered a real early date
John, That's about two months earlier than the average,most birds are in the 280/290 range,guess it depends on how critical one wants to be as far as numbers.Most are stamped K9/L9,being October / November of 69.
