Cars with HD 11" drums on front.. .same on rear? #1200780
03/21/12 12:28 PM
03/21/12 12:28 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
For mopars equipped with 11x3 HD brakes up front, are they the same in the rear? If not , what size?
TIA
Re: Cars with HD 11" drums on front.. .same on rear? [Re: MONC] #1200781
03/21/12 12:34 PM
03/21/12 12:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
11x2.5 in the rear
Re: Cars with HD 11" drums on front.. .same on rear? [Re: MONC] #1200782
03/21/12 12:37 PM
03/21/12 12:37 PM
Jackson, Mississippi
CornDogsCharger Offline
Fronts are 11x3 and rears are 11x2.5
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: Cars with HD 11" drums on front.. .same on rear? [Re: CornDogsCharger] #1200783
03/21/12 01:08 PM
03/21/12 01:08 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
There are a lot of 60's Chryslers with 11 inch rears, New Yorkers especially!
Re: Cars with HD 11" drums on front.. .same on rear? [Re: MO_PA] #1200784
03/21/12 03:13 PM
03/21/12 03:13 PM
MONC Offline OP
MONC  Offline OP
Thanks was thinking A,B,E body from 68-71 .
Are the wheel cylinders the same for all 4 ?
Re: Cars with HD 11" drums on front.. .same on rear? [Re: MONC] #1200785
03/21/12 04:16 PM
03/21/12 04:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Well your first problem is thinking A bodies had 11" brakes, they didn't.
Can't answer the wheel cylinder question till i have my parts manual in hand.
Re: Cars with HD 11" drums on front.. .same on rear? [Re: JohnRR] #1200786
03/21/12 04:20 PM
03/21/12 04:20 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Joe- The front wheel cylinders are larger in bore size. I just rebuilt the brake systems for both the '69 Bee and the '69 Swinger and the master cylinder, front and rear wheel cylinders were the same casting #'s. The front cylinders are 1 1/8" bore, while the rears are 1".
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Cars with HD 11" drums on front.. .same on rear? [Re: JohnRR] #1200787
03/21/12 04:21 PM
03/21/12 04:21 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Front to rear wheel cylinder castings are not the same, '68 front are not the same as '69 front.
Things changed so often, if you want accurate answers - you have to ask the specific questions.
Re: Cars with HD 11" drums on front.. .same on rear? [Re: 6bblgt] #1200788
03/21/12 04:25 PM
03/21/12 04:25 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Correct Dan, and the '68 11 X 2.5" rear drums are smooth, as opposed to the the finned '69-up. Then there is the backing plate changes for the different shaped wheel cylinder punchouts, etc...
Re: Cars with HD 11" drums on front.. .same on rear? [Re: JohnRR] #1200789
03/22/12 12:29 AM
03/22/12 12:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Wheel cylinders are side specific and the same on B/E 10"/11" ... can't be used on the rear... and the same side to side 10"/11" on the rear.
Re: Cars with HD 11" drums on front.. .same on rear? [Re: 70440+6bbl] #1200790
03/22/12 12:31 AM
03/22/12 12:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Casting numbers may be the same but the machining is different , front and rear are different, brake line goes into the rear straight and at an angle on the front and why they are side specific.
Re: Cars with HD 11" drums on front.. .same on rear? [Re: JohnRR] #1200791
03/22/12 12:39 AM
03/22/12 12:39 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Correct, I was mentioning to the OP that the casting #'s for the master cylinder, and all four wheel cylinders were the same from the '69 Bee to the '69 Swinger. The fronts are indeed side specific.
Re: Cars with HD 11" drums on front.. .same on rear? [Re: 70440+6bbl] #1200792
03/22/12 12:48 AM
03/22/12 12:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I missed the master cylinder part but you are correct , the wheel cylinders are the same A body and B body in 1969, confirmed in my parts manual and that is nuts. I'm changing my rears on the dart to 7/8" I got from Ebogger .
Re: Cars with HD 11" drums on front.. .same on rear? [Re: JohnRR] #1200793
03/22/12 08:15 AM
03/22/12 08:15 AM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
My 68 New Yorker had the towing package that included 11X3 drums on all four corners.They were not self adjusting.
The shoes were the same front and back.
The drums and wheel cylinders were different front and back.
Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
