Re: Cars with HD 11" drums on front.. .same on rear?
[Re: MONC]
#1200781
03/21/12 12:34 PM
03/21/12 12:34 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
[Re: MONC]
#1200782
03/21/12 12:37 PM
03/21/12 12:37 PM
Posts: 412 Jackson, Mississippi
CornDogsCharger
Fronts are 11x3 and rears are 11x2.5
Justin "CornDog"
1966 Dodge Charger 1968 Plymouth Satellite (Un-Restored "Survivor") 1969 Dodge Charger (W.B. General Lee) 1969 Dodge Charger (Future DMCL Clone) 1969 Dodge Super Bee, 383 4spd
[Re: MONC]
#1200785
03/21/12 04:16 PM
03/21/12 04:16 PM
JohnRR
U.S.S.A.
Thanks was thinking A,B,E body from 68-71 . Are the wheel cylinders the same for all 4 ?
Well your first problem is thinking A bodies had 11" brakes, they didn't.
Can't answer the wheel cylinder question till i have my parts manual in hand.
[Re: JohnRR]
#1200786
03/21/12 04:20 PM
03/21/12 04:20 PM
Posts: 5,268 NY
70440+6bbl
NY
Joe- The front wheel cylinders are larger in bore size. I just rebuilt the brake systems for both the '69 Bee and the '69 Swinger and the master cylinder, front and rear wheel cylinders were the same casting #'s. The front cylinders are 1 1/8" bore, while the rears are 1".
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: JohnRR]
#1200789
03/22/12 12:29 AM
03/22/12 12:29 AM
JohnRR
U.S.S.A.
Wheel cylinders are side specific and the same on B/E 10"/11" ... can't be used on the rear... and the same side to side 10"/11" on the rear.
[Re: 70440+6bbl]
#1200790
03/22/12 12:31 AM
03/22/12 12:31 AM
JohnRR
U.S.S.A.
Casting numbers may be the same but the machining is different , front and rear are different, brake line goes into the rear straight and at an angle on the front and why they are side specific.
[Re: JohnRR]
#1200791
03/22/12 12:39 AM
03/22/12 12:39 AM
Posts: 5,268 NY
70440+6bbl
NY
Correct, I was mentioning to the OP that the casting #'s for the master cylinder, and all four wheel cylinders were the same from the '69 Bee to the '69 Swinger. The fronts are indeed side specific.
[Re: 70440+6bbl]
#1200792
03/22/12 12:48 AM
03/22/12 12:48 AM
JohnRR
U.S.S.A.
I missed the master cylinder part but you are correct , the wheel cylinders are the same A body and B body in 1969, confirmed in my parts manual and that is nuts. I'm changing my rears on the dart to 7/8" I got from Ebogger .
[Re: JohnRR]
#1200793
03/22/12 08:15 AM
03/22/12 08:15 AM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
My 68 New Yorker had the towing package that included 11X3 drums on all four corners.They were not self adjusting. The shoes were the same front and back. The drums and wheel cylinders were different front and back. Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
