will stock rocker/stands work on indy 426 hipo? #1200418
03/20/12 06:58 PM
03/20/12 06:58 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Says the exh valve is rotated 2° so was wondering if my stoke style rocker stands will work with these heads?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: will stock rocker/stands work on indy 426 hipo? [Re: toplescuda] #1200419
03/20/12 08:31 PM
03/20/12 08:31 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i thought they had cast in stands, .
Re: will stock rocker/stands work on indy 426 hipo? [Re: lewtot184] #1200420
03/20/12 08:48 PM
03/20/12 08:48 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Pic dont show stands
1971 charger
Re: will stock rocker/stands work on indy 426 hipo? [Re: toplescuda] #1200421
03/20/12 10:10 PM
03/20/12 10:10 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
Only the 426-1 -1R -1RA etc have cast in stands. The SR and HiPo do not.
School of Automotive Machinists Racing
Re: will stock rocker/stands work on indy 426 hipo? [Re: lewtot184] #1200422
03/20/12 11:10 PM
03/20/12 11:10 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
all Indy hemi's have cast in stands except the billet pro mod version. regular hemi rockers are what is used with them. for rockers if you don't have any yet be sure to get the lastest ones like stagev makes that have oiling holes correct
home of the
Sox and Martin Hemi Duster
Re: will stock rocker/stands work on indy 426 hipo? [Re: moparman89] #1200423
03/20/12 11:15 PM
03/20/12 11:15 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Ok what is it??????????some of you are saying they dont have cast stands and some of you say they do head im refering to is the indy 426 hipo
1971 charger
Re: will stock rocker/stands work on indy 426 hipo? [Re: toplescuda] #1200424
03/20/12 11:32 PM
03/20/12 11:32 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Can you post a picture? Otherwise you might want to ask a dealer. That is a fairly new head for Indy.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: will stock rocker/stands work on indy 426 hipo? [Re: Hemi Allstate] #1200425
03/20/12 11:40 PM
03/20/12 11:40 PM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
Yes,factory parts fit.
If you need them Indy offers adjustable rocker stands.They use shims like B/RB,under the shafts.
Re: will stock rocker/stands work on indy 426 hipo? [Re: gillman34] #1200426
03/20/12 11:47 PM
03/20/12 11:47 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
So that means ol man fred is wrong about some hemi stuff?
1971 charger
Re: will stock rocker/stands work on indy 426 hipo? [Re: toplescuda] #1200427
03/21/12 10:24 AM
03/21/12 10:24 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, the new Indy SR and HiPo take the regular hemi rocker setup.
2011 Drag Pak Challenger
Re: will stock rocker/stands work on indy 426 hipo? [Re: rickseeman] #1200428
03/21/12 12:13 PM
03/21/12 12:13 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Will it benifit to get the improved geometry stands? The ones that are .060 taller and wider? Thanks Tim
Re: will stock rocker/stands work on indy 426 hipo? [Re: astjp2] #1200429
03/21/12 12:44 PM
03/21/12 12:44 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Ralph
You may want to order the right pistons for these heads too. We ordered a set from Wiseco and they did not work. Too much clearance (over 1/2 inch) on the exhaust valve and no clearance on the intake valve. Cut the intakes over 200 thousands and they still would not work. Called Wiseco back and the same person told us they must have wrote the order down wrong for the HIPO heads. Said they have a different piston for them.
I don't think you will have any issues with your rocker stands. We used KB stands but they fit a stock head as well. The intake and exhaust Rockers all seemed to center over the valves. These heads really look like/remind me of pictures on here of a set of heads that just came from the head porters. they have the brass tubes for the push rods running through the side of the port walls.
Old Geezer Racing
Re: will stock rocker/stands work on indy 426 hipo? [Re: toplescuda] #1200430
06/07/12 01:18 AM
06/07/12 01:18 AM
tn
robnbird Offline
robnbird  Offline
tn
yes your factory stands will work. And no they don't have built in stands Freddy . You will need custom pistons or order the pistons / with the heads from Indy. You can get them just at the same price or possibly for less streight from Indy. I made the stupid mistake of using a indy dealer. That will not happen again. We will see soon.
Re: will stock rocker/stands work on indy 426 hipo? [Re: HEMIFRED] #1200431
06/07/12 01:25 AM
06/07/12 01:25 AM
tn
robnbird Offline
robnbird  Offline
tn
I know you are just trying to help but, the hipo uses the stands just like factory ( factory type will work ). Now you can answer correctly.
