will stock rocker/stands work on indy 426 hipo?
#1200418
03/20/12 06:58 PM
03/20/12 06:58 PM
Posts: 8,852 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Says the exh valve is rotated 2° so was wondering if my stoke style rocker stands will work with these heads?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: will stock rocker/stands work on indy 426 hipo?
[Re: toplescuda]
#1200421
03/20/12 10:10 PM
03/20/12 10:10 PM
Posts: 171 Indy
moparman89
Indy
Only the 426-1 -1R -1RA etc have cast in stands. The SR and HiPo do not.
School of Automotive Machinists Racing
[Re: moparman89]
#1200423
03/20/12 11:15 PM
03/20/12 11:15 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Ok what is it??????????some of you are saying they dont have cast stands and some of you say they do head im refering to is the indy 426 hipo
[Re: toplescuda]
#1200424
03/20/12 11:32 PM
03/20/12 11:32 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Can you post a picture? Otherwise you might want to ask a dealer. That is a fairly new head for Indy. Mark ![](/ubbthreads/images/graemlins/Twocents.gif)
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: astjp2]
#1200429
03/21/12 12:44 PM
03/21/12 12:44 PM
Posts: 1,505 TN
SCATPACK 1
TN
Ralph You may want to order the right pistons for these heads too. We ordered a set from Wiseco and they did not work. Too much clearance (over 1/2 inch) on the exhaust valve and no clearance on the intake valve. Cut the intakes over 200 thousands and they still would not work. Called Wiseco back and the same person told us they must have wrote the order down wrong for the HIPO heads. Said they have a different piston for them. I don't think you will have any issues with your rocker stands. We used KB stands but they fit a stock head as well. The intake and exhaust Rockers all seemed to center over the valves. These heads really look like/remind me of pictures on here of a set of heads that just came from the head porters. they have the brass tubes for the push rods running through the side of the port walls.
Old Geezer Racing
[Re: toplescuda]
#1200430
06/07/12 01:18 AM
06/07/12 01:18 AM
Posts: 914 tn
robnbird
tn
yes your factory stands will work. And no they don't have built in stands Freddy . You will need custom pistons or order the pistons / with the heads from Indy. You can get them just at the same price or possibly for less streight from Indy. I made the stupid mistake of using a indy dealer. That will not happen again. We will see soon.
[Re: HEMIFRED]
#1200431
06/07/12 01:25 AM
06/07/12 01:25 AM
Posts: 914 tn
robnbird
tn
i thought they had cast in stands, .
all Indy hemi's have cast in stands except the billet pro mod version. regular hemi rockers are what is used with them. for rockers if you don't have any yet be sure to get the lastest ones like stagev makes that have oiling holes correct
I know you are just trying to help but, the hipo uses the stands just like factory ( factory type will work ). Now you can answer correctly. ![](/ubbthreads/images/graemlins/grin.gif)
