B&M deep pan on 727 -How much fluid? #1200158
03/20/12 12:46 PM
03/20/12 12:46 PM
Penna
70satelliteguy Offline OP
Penna
I have the B&M Aluminum pan on my 727. Supposed to hold 2-4 more quarts than stock I put in 8 quarts and the tailshaft seal is leaking fluid when the car runs . Do I have too much in the trans and this is causing the leak? The seal is new and I do not think I damaged it when installing the driveshaft!
Thanks Mike
Re: B&M deep pan on 727 -How much fluid? [Re: 70satelliteguy] #1200159
03/20/12 12:55 PM
03/20/12 12:55 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
the dipstick should still be used for the level
Re: B&M deep pan on 727 -How much fluid? [Re: 70satelliteguy] #1200160
03/20/12 01:06 PM
03/20/12 01:06 PM
organ
maximum entropy Offline
organ
dipstick jimmie!!!
even overfilled, the tailshaft seal shouldn't leak. you sure it isn't the rear servo shaft o rings?
Re: B&M deep pan on 727 -How much fluid? [Re: maximum entropy] #1200161
03/20/12 02:15 PM
03/20/12 02:15 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Sounds about right for the fluid level (but check your dipstick....JIMMY!!! ). I would guess you have a problem with the seal. Does your yoke have a smooth surface?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: B&M deep pan on 727 -How much fluid? [Re: 70satelliteguy] #1200162
03/20/12 02:48 PM
03/20/12 02:48 PM
I have both the B&M and the Mopar deep steel pans, I always run the fluid to the add mark on the stock dipstick when cold The tailshaft leak is not related to the amount of fluid in the pan
Re: B&M deep pan on 727 -How much fluid? [Re: 70satelliteguy] #1200163
03/20/12 03:26 PM
03/20/12 03:26 PM
Texas
6packattk Offline
6packattk  Offline
Texas
My solution is buy a new oil drain container at walmart and fix seal leak and reinstall till doesnt leak then not wasting all the new fluid.I had to do that after my complete tranny and engine build went south and had to repull engine and tranny.Oil I reused in daily drivers,tranny fluid will go back in new tranny using filtered funnel.I feel your pain although my pain is years old now.I also have the b&m pan.Dip stick level doesnt change,I am using royal purple tranny fluid,not wasting it.
Re: B&M deep pan on 727 -How much fluid? [Re: 70satelliteguy] #1200164
03/20/12 05:26 PM
03/20/12 05:26 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
did u check the calibration on ur dip stick. it could be off. seeya.
Re: B&M deep pan on 727 -How much fluid? [Re: 70satelliteguy] #1200165
03/20/12 05:27 PM
03/20/12 05:27 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Thanks Mike
trans will hold 8qts plus the converter for about 9 and add 3.5 for the deep pan...about 12 or until the Dip Stick shows full...leaking out means ya dont have a good seal around the shaft...
Re: B&M deep pan on 727 -How much fluid? [Re: smokinwoody] #1200166
03/20/12 07:52 PM
03/20/12 07:52 PM
southwest pa
bodyworks racing Offline
southwest pa
I always put a lite coat of grease on the tail shaft so as not to rip the seal
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: B&M deep pan on 727 -How much fluid? [Re: bodyworks racing] #1200167
03/21/12 08:50 AM
03/21/12 08:50 AM
Penna
Penna
Thanks for all of the replys
Do I have to drain the tranny to replace that rear seal?
Thanks MIke
Re: B&M deep pan on 727 -How much fluid? [Re: 70satelliteguy] #1200168
03/21/12 09:03 AM
03/21/12 09:03 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
fluid should be drained back to the pan...yes there will be some in the tailshaft...pull it and replace it...just be prepared for some...
Re: B&M deep pan on 727 -How much fluid? [Re: smokinwoody] #1200169
03/21/12 09:36 AM
03/21/12 09:36 AM
gregsdart Offline
gregsdart  Offline
Put the rear axle up on jack stands only. Shouldn't lose fluid while changing seal.
Re: B&M deep pan on 727 -How much fluid? [Re: gregsdart] #1200170
03/21/12 10:08 AM
03/21/12 10:08 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
whats a little fluid among friends anyways...
Re: B&M deep pan on 727 -How much fluid? [Re: smokinwoody] #1200171
03/21/12 03:21 PM
03/21/12 03:21 PM
Penna
Penna
Parts store says it has two seals to fit the 727. One with a short piece of rubber that goes around the yoke and another with a longer one. Which one is better? Also, someone said to use a piece of 2-1/2 in pvc pipe(id) with a cap on the end to tap the seal in place without causing any damage Any comments.
Thanks Guy's
Mike
Re: B&M deep pan on 727 -How much fluid? [Re: 70satelliteguy] #1200172
03/21/12 05:33 PM
03/21/12 05:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
the longer seal is just a dust shield. i used a 1 1/2 plastic coupling. worked great. seeya.
Re: B&M deep pan on 727 -How much fluid? [Re: rickraw] #1200173
03/21/12 09:32 PM
03/21/12 09:32 PM
Penna
Penna
Mike
