B&M deep pan on 727 -How much fluid?
#1200158
03/20/12 12:46 PM
03/20/12 12:46 PM
Posts: 1,301 Penna
70satelliteguy
Penna
I have the B&M Aluminum pan on my 727. Supposed to hold 2-4 more quarts than stock I put in 8 quarts and the tailshaft seal is leaking fluid when the car runs . Do I have too much in the trans and this is causing the leak? The seal is new and I do not think I damaged it when installing the driveshaft! Thanks Mike
Re: B&M deep pan on 727 -How much fluid?
[Re: 70satelliteguy]
#1200160
03/20/12 01:06 PM
03/20/12 01:06 PM
Posts: 5,080 organ
maximum entropy
organ
dipstick jimmie!!! even overfilled, the tailshaft seal shouldn't leak. you sure it isn't the rear servo shaft o rings?
[Re: maximum entropy]
#1200161
03/20/12 02:15 PM
03/20/12 02:15 PM
Posts: 1,178 Indy
FlyFish
Indy
Sounds about right for the fluid level (but check your dipstick....JIMMY!!! ). I would guess you have a problem with the seal. Does your yoke have a smooth surface?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
#1200162
03/20/12 02:48 PM
03/20/12 02:48 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
I have both the B&M and the Mopar deep steel pans, I always run the fluid to the add mark on the stock dipstick when cold The tailshaft leak is not related to the amount of fluid in the pan
#1200165
03/20/12 05:27 PM
03/20/12 05:27 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
trans will hold 8qts plus the converter for about 9 and add 3.5 for the deep pan...about 12 or until the Dip Stick shows full...leaking out means ya dont have a good seal around the shaft...
[Re: bodyworks racing]
#1200167
03/21/12 08:50 AM
03/21/12 08:50 AM
Posts: 1,301 Penna
70satelliteguy
Penna
Thanks for all of the replys Do I have to drain the tranny to replace that rear seal? Thanks MIke
[Re: smokinwoody]
#1200171
03/21/12 03:21 PM
03/21/12 03:21 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Parts store says it has two seals to fit the 727. One with a short piece of rubber that goes around the yoke and another with a longer one. Which one is better? Also, someone said to use a piece of 2-1/2 in pvc pipe(id) with a cap on the end to tap the seal in place without causing any damage Any comments. Thanks Guy's Mike
