Re: How do I find out where my convertor "flashes" at???
[Re: nosboy]
#1199589
03/19/12 04:53 PM
03/19/12 04:53 PM
Posts: 5,080 organ
maximum entropy
organ
with everything warmed up, put it in high gear, watch the tach, and slam the gas as if launching (hold the brakes). the rpm should spike a couple of hundred rpm above stall (that's flash), and then almost immediately settle down to stall speed. the whole test should be done in just a couple of seconds. did your convertor supplier get the dyno sheet when building the convertor?
[Re: maximum entropy]
#1199590
03/19/12 05:02 PM
03/19/12 05:02 PM
Posts: 401 dayton,ohio
ROSSIO
dayton,ohio
my personal opinion----stop right now,get all your info together and call ultimate converters--talk to lenny,he can steer you into the right direction. i had T/C problems--all the fast guys use him--prices are great,he helped me i have a 500 PLUS cu B1MC pushing 1100 hp--i was not going to play around--lenny hooked me up fast & friendly service
ross
1970 DART B1MC N/A
8.86@ [Email]155
3200 lb on 275 DR
5.30 @ 130 1/8
[Re: ROSSIO]
#1199591
03/19/12 05:15 PM
03/19/12 05:15 PM
Posts: 205 Chicago,Illinois
nosboy
Chicago,Illinois
as far as the dyno sheet.. I filled out the build sheet and gave him the specs BEFORE the motor was finished and ran on the dyno.. so,, NO,, he never saw the dyno sheet.. but.. he did know the cam, heads, pistons, etc,etc etc...I was told by the builder to have a convertor around 500rpm HIGHER than "flash"... I have another convertor that my friend will give me to "use" to see what his convertor does,, but,, I THINK I NEED to send the DYNOP SHEETS to someone who builds convertors that knows what he is doing.... The guy in Alabama didn't take into consideration that I had a mid plate EVEN THOUGH I told him in the BUILD SHEET !!! The convertor "SNOUT didn't fit properly into the "register" of the crankshaft and I went as far as CALLIES ENGINEERING to prove the crank register was in the right place... I spaced the flex plate out .070 to take up for the thickness of the midplate and the convertor would have NEVER FIT if I didn't do that.. it would NOT sit flat against the flex plate because it was MADE WRONG from the start.. PISSED OFF at the convertor Manufacturer.. and I TOLD the builder that also !!! The builder was MORE THAN HELPFUL and was willing to replace the convertor and have the convertor builder eat it,, but,, I didn't want to make a SCENE because the thing DID FIT with the .070 spacer on the crank to flexplate.. It was a FLIPPING NIGHTMARE.. !!! The convertor guy SUCKS..!!!
[Re: nosboy]
#1199592
03/19/12 05:23 PM
03/19/12 05:23 PM
Posts: 20,667 in a cattle trailer down by th...
Guitar Jones
I don't know of anyone going fast with an Alabama torque converter. I learned my lesson. I have a Hughes that will slow any car down. Choose your company wisely.
[Re: nosboy]
#1199594
03/19/12 08:19 PM
03/19/12 08:19 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Go see Lenny at ultimate, he will get you fixed up. I sixty foot better with a small block.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1199595
03/19/12 08:31 PM
03/19/12 08:31 PM
Posts: 189 long island new york
kingdust
Dynamic converters can take care of you also. Talk to Frank Lupo. He's been racing mopars a long time and is very friendly on the phone.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
[Re: Eric]
#1199599
03/19/12 09:41 PM
03/19/12 09:41 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
I agree that you need to call Lenny too. He will get you what you need and it will WORK. That Alabama deal sounds like a company that I got screwed over by a few years ago- GER in PA. Anyone on the board remember them? ![](/ubbthreads/images/graemlins/tsk.gif)
[Re: actionange]
#1199600
03/19/12 10:39 PM
03/19/12 10:39 PM
ROSSIO
dayton,ohio
see--told you------call lenny @ ultimate converter. like the other guy said--NO to dynamic,i've had theirs,good work i will say--but their service and phone edicit is poor and their prices are wayyyy too high look in the "fastest street car mag"--ultimate is everywhere.
ross
1970 DART B1MC N/A
8.86@ [Email]155
3200 lb on 275 DR
5.30 @ 130 1/8
[Re: Dave64]
#1199602
03/20/12 09:47 AM
03/20/12 09:47 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I ran A GER A few years ago that I bought off ebay. It worked great but the part that slipped into the seal was to small or no prefectly round and I couldnt keep A front seal in it. I went through about 4 or 5 seals befor I figured out it was the converter. Now am running A Coan 8" and seems to be working really good with a 1.49 60' off the foot brake.
67' charger 499 RB
10.57 at 127
