How do I find out where my convertor "flashes" at??? #1199586
03/19/12 04:18 PM
03/19/12 04:18 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
I have a 73 Challenger with a 4.500 X 4.500 wedge engine.. 572 CUBIC INCH with Indy 440-1 heads ( cnc325).. MY 60 FOOTS ARE AROUND 1.57 and it launches like there's something wrong with it.. the Trans is NOT SLIPPING ( I think) and the convertor is one of those ALABAMA convertor company's $1000.00 dollar convertor... SPECIALLY MADE for my setup... Could someone PLEASE explain the "flashes" theory and also explain the " formula" for finding out which convertor to use???? I DO HAVE a DYNO SHEET for the engine...
Thanks in Advance,, Gary Oles nosboyracing
Re: How do I find out where my convertor "flashes" at??? [Re: nosboy] #1199587
03/19/12 04:20 PM
03/19/12 04:20 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
The car weighs 3270 without me in it and I weigh around 230-240.. Right around 3500 lbs with a DANA 60 with 4:56 gear... 32/14/15 meats at 9.5 psi...
Re: How do I find out where my convertor "flashes" at??? [Re: nosboy] #1199588
03/19/12 04:33 PM
03/19/12 04:33 PM
Several ways are used, one is to put the tranny in high gear, manual shift valve body, and roll it along in high gear at or close to 1500 RPM, smash the throttle while watching the tach, the RPM the motors revvs up to is the flash RPM. I have a playback tach and it shows my 8 inch race converter to flash to 5200 in low gear, it will flash higher in high gear when I test it You can also test it in low gear by foot stalling it and then wacking the throttle while watching the tach, I'm more concerned on the low gear results and the RPM drop between gears when shifting than what it will flash in high gear BTW, my 518 C.I. pump gas motor in a 3450 Lb Duster with ET street tires runs 1.43 sixty foots on a good track Check your shifter cable adjustment I have seen that problem slow a lot of cars down, there slugs when the shifters are not adjusted correctly
Re: How do I find out where my convertor "flashes" at??? [Re: nosboy] #1199589
03/19/12 04:53 PM
03/19/12 04:53 PM
organ
maximum entropy Offline
organ
with everything warmed up, put it in high gear, watch the tach, and slam the gas as if launching (hold the brakes). the rpm should spike a couple of hundred rpm above stall (that's flash), and then almost immediately settle down to stall speed. the whole test should be done in just a couple of seconds. did your convertor supplier get the dyno sheet when building the convertor?
Re: How do I find out where my convertor "flashes" at??? [Re: maximum entropy] #1199590
03/19/12 05:02 PM
03/19/12 05:02 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
my personal opinion----stop right now,get all your info together
and call ultimate converters--talk to lenny,he can steer you into
the right direction.
i had T/C problems--all the fast guys use him--prices are great,he helped me
i have a 500 PLUS cu B1MC pushing 1100 hp--i was not going to play around--lenny hooked me up
fast & friendly service
ross
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: How do I find out where my convertor "flashes" at??? [Re: ROSSIO] #1199591
03/19/12 05:15 PM
03/19/12 05:15 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
as far as the dyno sheet.. I filled out the build sheet and gave him the specs BEFORE the motor was finished and ran on the dyno.. so,, NO,, he never saw the dyno sheet.. but.. he did know the cam, heads, pistons, etc,etc etc...I was told by the builder to have a convertor around 500rpm HIGHER than "flash"... I have another convertor that my friend will give me to "use" to see what his convertor does,, but,, I THINK I NEED to send the DYNOP SHEETS to someone who builds convertors that knows what he is doing.... The guy in Alabama didn't take into consideration that I had a mid plate EVEN THOUGH I told him in the BUILD SHEET !!! The convertor "SNOUT didn't fit properly into the "register" of the crankshaft and I went as far as CALLIES ENGINEERING to prove the crank register was in the right place... I spaced the flex plate out .070 to take up for the thickness of the midplate and the convertor would have NEVER FIT if I didn't do that.. it would NOT sit flat against the flex plate because it was MADE WRONG from the start.. PISSED OFF at the convertor Manufacturer.. and I TOLD the builder that also !!!
The builder was MORE THAN HELPFUL and was willing to replace the convertor and have the convertor builder eat it,, but,, I didn't want to make a SCENE because the thing DID FIT with the .070 spacer on the crank to flexplate.. It was a FLIPPING NIGHTMARE.. !!! The convertor guy SUCKS..!!!
Re: How do I find out where my convertor "flashes" at??? [Re: nosboy] #1199592
03/19/12 05:23 PM
03/19/12 05:23 PM
Guitar Jones Offline
I don't know of anyone going fast with an Alabama torque converter. I learned my lesson. I have a Hughes that will slow any car down. Choose your company wisely.
Re: How do I find out where my convertor "flashes" at??? [Re: Guitar Jones] #1199593
03/19/12 08:08 PM
03/19/12 08:08 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
Performance Torque convertors,, Muscle Shoals, Alabama...
Re: How do I find out where my convertor "flashes" at??? [Re: nosboy] #1199594
03/19/12 08:19 PM
03/19/12 08:19 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Go see Lenny at ultimate, he will get you fixed up. I sixty foot better with a small block.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: How do I find out where my convertor "flashes" at??? [Re: 1967dartgt] #1199595
03/19/12 08:31 PM
03/19/12 08:31 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
Dynamic converters can take care of you also. Talk to Frank Lupo. He's been racing mopars a long time and is very friendly on the phone.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: How do I find out where my convertor "flashes" at??? [Re: kingdust] #1199596
03/19/12 08:42 PM
03/19/12 08:42 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Wouldn't wish him on my worst enemey, had one once went back three times and then gave up.
Re: How do I find out where my convertor "flashes" at??? [Re: 1967dartgt] #1199597
03/19/12 08:54 PM
03/19/12 08:54 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Call Lenny and prepare to smile
5.53 @ 125 1/8th on the launch control..more left in her!
Re: How do I find out where my convertor "flashes" at??? [Re: nosboy] #1199598
03/19/12 09:39 PM
03/19/12 09:39 PM
PA
FHW Offline
FHW  Offline
PA
PTC I have there 9.5 non lockup 4000 stall in my 87 buick GN very satisfied excellent converter.In the turbo buick world PTC has the rep,as the best most all the fastest cars use a PTC. Sorry to hear you did not have good results with them
Re: How do I find out where my convertor "flashes" at??? [Re: Eric] #1199599
03/19/12 09:41 PM
03/19/12 09:41 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I agree that you need to call Lenny too. He will get you what you need and it will WORK.
That Alabama deal sounds like a company that I got screwed over by a few years ago- GER in PA.
Anyone on the board remember them?
Re: How do I find out where my convertor "flashes" at??? [Re: actionange] #1199600
03/19/12 10:39 PM
03/19/12 10:39 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
see--told you------call lenny @ ultimate converter.
like the other guy said--NO to dynamic,i've had theirs,good work i will say--but their service and phone edicit is poor and their prices are wayyyy too high
look in the "fastest street car mag"--ultimate is everywhere.
ross
Re: How do I find out where my convertor "flashes" at??? [Re: ROSSIO] #1199601
03/20/12 12:26 AM
03/20/12 12:26 AM
Oklahoma City, OK
Dave64 Offline
Dave64  Offline
Oklahoma City, OK
Have not had experience with Lenny so can't say but I have had very good results with PTC talk to Kenny Ford
Re: How do I find out where my convertor "flashes" at??? [Re: Dave64] #1199602
03/20/12 09:47 AM
03/20/12 09:47 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I ran A GER A few years ago that I bought off ebay. It worked great but the part that slipped into the seal was to small or no prefectly round and I couldnt keep A front seal in it. I went through about 4 or 5 seals befor I figured out it was the converter. Now am running A Coan 8" and seems to be working really good with a 1.49 60' off the foot brake.
67' charger 499 RB 10.57 at 127
Re: How do I find out where my convertor "flashes" at??? [Re: 1967dartgt] #1199603
03/20/12 04:26 PM
03/20/12 04:26 PM
K
kingdust Offline
kingdust  Offline
K
sorry to hear that. 2 of my friends I built motors for have his converters and no problems. My other friend has been running the same converter for 13 years in his duster and runs low 9s all day. Me, I run a stick! Lol.
Re: How do I find out where my convertor "flashes" at??? [Re: kingdust] #1199604
03/20/12 06:47 PM
03/20/12 06:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also use Luppo's Dynamic converters and never a problem. I use his 9.5 converter for a street/strip car. Ron
Re: How do I find out where my convertor "flashes" at??? [Re: 383man] #1199605
03/20/12 08:09 PM
03/20/12 08:09 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Ditto
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
