Dealer installed Hitches from back in the day #1199444
03/19/12 12:07 PM
03/19/12 12:07 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I have an itch...to find this hitch.
I tried looking for one about a year ago to no avail. Maybe someone else will read this and someone (if I could be that lucky) will actually know where to find one.
Looking for a Dealer installed Class I hitch for a 68 - 70 Charger. It is actually stamped on the hitch "68 - 70 Charger" on the underside. My idiot friend removed it to take it to a car show because he thought it wasn't "original" while I was overseas. Would like to find one just out of personal thrill and mount it. I am not going to pull anything with it. Even if you have any information, maybe an old magazine with the company name and design of the hitch. Perhaps a drawing of it from a brochure. Maybe you have a cruddy hitch on your car and you dont want it. It has a plate that mounts behind the license plate on the bumper. The tongue is about 1/2" thick steel, goes down under the gas tank and then connects left and right to the subframe with two bolts. There was a variation where it also has two trusses that went towards the rear diff about 8" with two more mounting points on each side.
If anyone can help I would greatly appreciate it.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Dealer installed Hitches from back in the day [Re: Pyper70] #1199445
03/19/12 04:55 PM
03/19/12 04:55 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The Owner's Manual that came with my 69 Barracuda had a drawing in back for making a hitch frame out of square tubing. Always wanted to make one, but never did.
Maybe check the Owner's Manual for your car...
Re: Dealer installed Hitches from back in the day [Re: kentj340] #1199446
03/19/12 05:07 PM
03/19/12 05:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I believe Draw Tite made them.
The ones I've seen just have part numbers on them.
I have one for my Barracuda it just has a Draw Tite number on it V-5. IIRC, mine also works for a Dart.
Re: Dealer installed Hitches from back in the day [Re: autoxcuda] #1199447
03/19/12 08:07 PM
03/19/12 08:07 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
My 70 Superbee had one like that. I held onto it for years & then loaned it to a friend to put on his Roadrunner just to pull a motorcycle trailer. I don't remember if I got it back or he still has it but I'll check.
It was on the Bee when I bought it in 75 & I remember the original owners pulled a boat with it.
Butch
Re: Dealer installed Hitches from back in the day [Re: autoxcuda] #1199448
03/19/12 08:07 PM
03/19/12 08:07 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Here is a lead. It is worth a try. I have been researching hitches for a while. Let me know what you find out because I'm adding thsiinformaiton to the ICCA reference manuals.
http://forums.aaca.org/f119/trailer-hitches-277721.html
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Dealer installed Hitches from back in the day [Re: MMC Detroit] #1199449
03/19/12 08:12 PM
03/19/12 08:12 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Allot of the Mopar ones back in that day had a rectangular box that framed the license plate... There is one of that style on a Dart in the local wrecking yard...
Re: Dealer installed Hitches from back in the day [Re: MMC Detroit] #1199450
03/19/12 08:26 PM
03/19/12 08:26 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have a feeling the Draw Tite number may change over time. Here are two setups that have V-5 marked on them.
http://losangeles.craigslist.org/sgv/pts/2910176970.html
http://newyork.ebayclassifieds.com/parts...itch/?ad=616126
Re: Dealer installed Hitches from back in the day [Re: Pyper70] #1199451
03/19/12 08:36 PM
03/19/12 08:36 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Look in a 69 B body owners manual and it will show how to make one and where to attach it.
Re: Dealer installed Hitches from back in the day [Re: 1_WILD_RT] #1199452
03/19/12 08:38 PM
03/19/12 08:38 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Like this?....
Re: Dealer installed Hitches from back in the day [Re: autoxcuda] #1199453
03/19/12 08:39 PM
03/19/12 08:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Like this?....
Yup..
Re: Dealer installed Hitches from back in the day [Re: 71birdJ68] #1199454
03/19/12 08:41 PM
03/19/12 08:41 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Are we talking the 69 Charger FSM or the little booklet for the glovebox? I have the 69 FSM and the 70 Glovebox manual. I'll take a peek tomorrow and see what it says
Re: Dealer installed Hitches from back in the day [Re: autoxcuda] #1199455
03/19/12 11:35 PM
03/19/12 11:35 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
I dont think this was dealer installed infact quite the hack job really. it was bolted to the bumper which was cut out and into the trunk pan with 1/4 plates under the bolts.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Dealer installed Hitches from back in the day [Re: 19cuda73] #1199456
03/19/12 11:38 PM
03/19/12 11:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That hitch didn't start it's life on that car.... Or at least it wasn't designed to start it's life on that car....
Re: Dealer installed Hitches from back in the day [Re: 1_WILD_RT] #1199457
03/20/12 12:32 AM
03/20/12 12:32 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
There is a similar trailer hitch on my '68 H/O. With carriage bolts thru the trunk floor to help support it.
Re: Dealer installed Hitches from back in the day [Re: Pyper70] #1199458
03/20/12 12:56 AM
03/20/12 12:56 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Look here:
http://www.faxonautoliterature.com/1969-Dodge-Charger-RT-Reprint-Owners-Manual-69-P10057.aspx
