Dealer installed Hitches from back in the day
#1199444
03/19/12 12:07 PM
03/19/12 12:07 PM
Posts: 5,904 Athens, Greece
Pyper70
Athens, Greece
I have an itch...to find this hitch.
I tried looking for one about a year ago to no avail. Maybe someone else will read this and someone (if I could be that lucky) will actually know where to find one.
Looking for a Dealer installed Class I hitch for a 68 - 70 Charger. It is actually stamped on the hitch "68 - 70 Charger" on the underside. My idiot friend removed it to take it to a car show because he thought it wasn't "original" while I was overseas. Would like to find one just out of personal thrill and mount it. I am not going to pull anything with it. Even if you have any information, maybe an old magazine with the company name and design of the hitch. Perhaps a drawing of it from a brochure. Maybe you have a cruddy hitch on your car and you dont want it. It has a plate that mounts behind the license plate on the bumper. The tongue is about 1/2" thick steel, goes down under the gas tank and then connects left and right to the subframe with two bolts. There was a variation where it also has two trusses that went towards the rear diff about 8" with two more mounting points on each side.
If anyone can help I would greatly appreciate it.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Dealer installed Hitches from back in the day
[Re: Pyper70]
#1199445
03/19/12 04:55 PM
03/19/12 04:55 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
The Owner's Manual that came with my 69 Barracuda had a drawing in back for making a hitch frame out of square tubing. Always wanted to make one, but never did.
Maybe check the Owner's Manual for your car...
[Re: kentj340]
#1199446
03/19/12 05:07 PM
03/19/12 05:07 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I believe Draw Tite made them.
The ones I've seen just have part numbers on them.
I have one for my Barracuda it just has a Draw Tite number on it V-5. IIRC, mine also works for a Dart.
[Re: MMC Detroit]
#1199449
03/19/12 08:12 PM
03/19/12 08:12 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Allot of the Mopar ones back in that day had a rectangular box that framed the license plate... There is one of that style on a Dart in the local wrecking yard...
[Re: MMC Detroit]
#1199450
03/19/12 08:26 PM
03/19/12 08:26 PM
autoxcuda
So Cal
[Re: 1_WILD_RT]
#1199452
03/19/12 08:38 PM
03/19/12 08:38 PM
autoxcuda
So Cal
Like this?....
[Re: autoxcuda]
#1199455
03/19/12 11:35 PM
03/19/12 11:35 PM
Posts: 1,300 Washington
19cuda73
Washington
I dont think this was dealer installed infact quite the hack job really. it was bolted to the bumper which was cut out and into the trunk pan with 1/4 plates under the bolts.
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
