I bet I'm the 1st to ever do this! #1198282
03/17/12 09:22 AM
03/17/12 09:22 AM
north cakalaky
I
instigator Offline OP
I
north cakalaky
Welded the 16 extra lugs on to my Resto block to help hold down the Indy 360-2 heads. Used the head as a template using a drill sleeve in the extra head bolt holes to line them up perfectly...got 3/8 ARP studs going in them....used stainless mig wire and Argon/helium to keep from cracking.....hope it works...and helps.
Don't try this with roller lifters.....I am using Smith machine composite solid flat-tappets and I ground out just enough material for them to sneak by.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: I bet I'm the 1st to ever do this! [Re: instigator] #1198283
03/17/12 09:32 AM
03/17/12 09:32 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I will be impressed if they stay there
Re: I bet I'm the 1st to ever do this! [Re: sshemi] #1198284
03/17/12 10:15 AM
03/17/12 10:15 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Are you going to at least deck the block to get those add a holes to the right height? If you are runing that much boost to that motor to lift the heads,you may be adding more holes to the main caps also. I would get a patten pending lable on this idea. Do you live in PA and Amish?
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: I bet I'm the 1st to ever do this! [Re: sshemi] #1198285
03/17/12 10:32 AM
03/17/12 10:32 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
x2
Re: I bet I'm the 1st to ever do this! [Re: rickraw] #1198286
03/17/12 11:05 AM
03/17/12 11:05 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Something similar used to be done on "B" blocks so Hemi Heads could be used on them...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: I bet I'm the 1st to ever do this! [Re: rickraw] #1198287
03/17/12 11:09 AM
03/17/12 11:09 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If they were migged I doubt they'll hold. Just the fact that we can see the parting lines at the top tells me you haven't penetrated the whole piece. You would have been better off to build up all those areas with weld bead than trying to weld on blocks. Good luck tho'!
Re: I bet I'm the 1st to ever do this! [Re: Stanton] #1198288
03/17/12 11:25 AM
03/17/12 11:25 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
its something i would try. good luck
Re: I bet I'm the 1st to ever do this! [Re: Stanton] #1198289
03/17/12 11:26 AM
03/17/12 11:26 AM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
No, ive seen many hacked up blocks ....id not post that kind of work untill I seen if it worked or not and then....sorta like the fat chick in high school, alot of fun until your friends see ya on it.
Re: I bet I'm the 1st to ever do this! [Re: A57_RT ] #1198290
03/17/12 12:38 PM
03/17/12 12:38 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
At least your trying, but if it does work, you will only find the next weak link.
Re: I bet I'm the 1st to ever do this! [Re: Dodgeguy101] #1198291
03/17/12 12:48 PM
03/17/12 12:48 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I hope they don't break off and go through the engine. Hope it works out for you.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: I bet I'm the 1st to ever do this! [Re: pittsburghracer] #1198292
03/17/12 12:53 PM
03/17/12 12:53 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
I do hope it does work for you though, ive a set of jacked up heads, im giving a 50/50 chance on them working.
Gotta think positive but at the same time....wonder a bit.
Re: I bet I'm the 1st to ever do this! [Re: A57_RT ] #1198293
03/17/12 01:50 PM
03/17/12 01:50 PM
north cakalaky
I
I
north cakalaky
The lugs are welded on the sides and on the bottom...not across the top, which is why the parting line can be seen...I feel confident on the welds....I don't mind being different and going outside the box. I'll know when the studs are tightened down if all holds well. Half of the thread is in the meat of the block where the original lugs were milled off due to tooling of the 59 degree lifter bore..This is a R3 block with 4 bolt mains, heavier walls, bulkheads,deck, and filled pan rails, Manley pro-series rods , callies crank and custom Ross turbo pistons and pins, so there ain't much left in the way of the next weakest link!
Waiting on 18 bolt head gaskets from SCE (coppers)
65 Barracuda
Re: I bet I'm the 1st to ever do this! [Re: instigator] #1198294
03/17/12 02:27 PM
03/17/12 02:27 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
I remember seeing a B engine with hemi heads on a prostocker late 70's early 80's. I know for a fact he had no throuble. The lugs both bolted and welded.
Re: I bet I'm the 1st to ever do this! [Re: instigator] #1198295
03/17/12 02:33 PM
03/17/12 02:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have welded on blocks many times but all I ever
used was nickle rod.... hope it works out for you...
easy way to test it is... hit it with a hammer...
hit the lug you welded on
Re: I bet I'm the 1st to ever do this! [Re: dodger mope] #1198296
03/17/12 02:44 PM
03/17/12 02:44 PM
Locomotion Offline
Locomotion  Offline
Yes, it was a guy named Charlie Malyuke who raced raced in Pro Stock and built some low deck big block "Hemi's" for himself and John Hagen around 1980-81 - 386 ci. John Hagen and that combo even set a MPH record. NHRA went to the 500 ci format in 1982.
Re: I bet I'm the 1st to ever do this! [Re: MR_P_BODY] #1198297
03/17/12 03:28 PM
03/17/12 03:28 PM
north cakalaky
I
I
north cakalaky
Exactly why I used stainless wire (for the nickel and similar expansion to cast) and I ran the studs in with stacked washers, torqued to 45ft lbs which is what they will be torqued to and I peened it with a hammer about 5-6 times each.
I always wonder in the back of my head sometimes on the things I do, but every reward in life involves risks.
65 Barracuda
Re: I bet I'm the 1st to ever do this! [Re: Locomotion] #1198298
03/18/12 12:17 AM
03/18/12 12:17 AM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
I think I still have that magazine article covering Charlie Malyuke's modifications--if I remember correctly, he used a silicon-bronze weld process.
Re: I bet I'm the 1st to ever do this! [Re: reknapp52] #1198299
03/18/12 12:26 AM
03/18/12 12:26 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I saw bolt on bosses for a big Ford and I liked the idea of it......A-460 heads on a stock block for po' folks like myself.
I never got that far , but I had some crazy combos back then because I would buy stuff , then figure out how to use it.
This works on paper..........let us know how it holds up on steel.
Re: I bet I'm the 1st to ever do this! [Re: reknapp52] #1198300
03/18/12 12:31 AM
03/18/12 12:31 AM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Good Luck to ya. Trying something different is what this hobby is all about
Just make sure you epoxy in some screen over the cam galley, just in case.
codfish
Re: I bet I'm the 1st to ever do this! [Re: reknapp52] #1198301
03/18/12 02:02 AM
03/18/12 02:02 AM
California
Mad Dart Offline
Mad Dart  Offline
California
I am sure it will hold since them extra Studs/Nuts are only going to be torqued to 45lbs. You only need enough so you don't pop a lung!!
