I have welded on blocks many times but all I ever used was nickle rod.... hope it works out for you... easy way to test it is... hit it with a hammer... hit the lug you welded on
Exactly why I used stainless wire (for the nickel and similar expansion to cast) and I ran the studs in with stacked washers, torqued to 45ft lbs which is what they will be torqued to and I peened it with a hammer about 5-6 times each.
I always wonder in the back of my head sometimes on the things I do, but every reward in life involves risks.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
