Green bearing question
#1198064
03/16/12 08:30 PM
03/16/12 08:30 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Hi there
Is it possible to use one green bearing and a regular bearing (non adjustable) on the other axle instead of two green bearing pr. housing?
Regards
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Green bearing question
[Re: savoy64]
#1198067
03/17/12 06:23 PM
03/17/12 06:23 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Thanks for replying guys. I already have two new green bearings ready but this thought just crossed my mind.
Regards
Ragnar in Iceland
[Re: Cab_Burge]
#1198071
03/18/12 02:27 PM
03/18/12 02:27 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Hi guys, Thanks for mulling this over, some more.
Like I said, this question just struck my mind and instead of contacting Mythbusters I wrote on Moparts with the predictable quick and favorable results. This is not something that I want to do, but I live a long ways from any decent parts store so sometimes necessity is the mother of invention. Now, me and others know that this is at least a possible set-up should the occasion arise.
Regards
Ragnar in Iceland
[Re: BadMoonRacer]
#1198072
03/19/12 12:36 AM
03/19/12 12:36 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Regards
Ragnar in Iceland
Is it easier to get a green vs. an A7 bearing in iceland ?
[Re: cageman]
#1198074
03/19/12 03:08 AM
03/19/12 03:08 AM
Posts: 43,214 Bend,OR USA
Cab_Burge
Since the tapered needs the other side to be adjustable, it cant be used ever with a green, plus the green, if used with the other side a tapered adjustable, wouldnt like the side load it would have to take to get the tapered roller seated properly. two greens, or two tapered. not one of each.
Wrong, as long as the Tapered Timken roller bearings are limited on how much side movement they can make, IE less than .005 the OP should be good. OP if it is more than .005 use another green bearing on the other side also
