Green bearing question #1198064
03/16/12 08:30 PM
03/16/12 08:30 PM
Iceland
BadMoonRacer Offline OP
Iceland
Hi there
Is it possible to use one green bearing and a regular bearing (non adjustable) on the other axle instead of two green bearing pr. housing?
Regards
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Green bearing question [Re: BadMoonRacer] #1198065
03/16/12 10:11 PM
03/16/12 10:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not really.
Re: Green bearing question [Re: stumpy] #1198066
03/16/12 11:14 PM
03/16/12 11:14 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
it may be possible to use the green with the adjustable bearing on the other side but i cant see it the other way---bob
Re: Green bearing question [Re: savoy64] #1198067
03/17/12 06:23 PM
03/17/12 06:23 PM
Iceland
Iceland
Thanks for replying guys. I already have two new green bearings ready but this thought just crossed my mind.
Regards
Ragnar in Iceland
Re: Green bearing question [Re: BadMoonRacer] #1198068
03/17/12 07:09 PM
03/17/12 07:09 PM
You could try it on the non adjustable side first and see if the adjsutable side will loosen up or tighten up enough to get the recommended end play, .001 to .006 or close to that, on the thrust If not then use the other bearing
Re: Green bearing question [Re: Cab_Burge] #1198069
03/17/12 09:58 PM
03/17/12 09:58 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
My question is why would you want to????
Re: Green bearing question [Re: MoparforLife] #1198070
03/17/12 11:39 PM
03/17/12 11:39 PM
It looks like he wants to It says in one set of instructions I have with a set of green bearings that is the way to do it if your not replacing both sides
Re: Green bearing question [Re: Cab_Burge] #1198071
03/18/12 02:27 PM
03/18/12 02:27 PM
Iceland
Iceland
Hi guys,
Thanks for mulling this over, some more.
Like I said, this question just struck my mind and instead of contacting Mythbusters I wrote on Moparts with the predictable quick and favorable results. This is not something that I want to do, but I live a long ways from any decent parts store so sometimes necessity is the mother of invention. Now, me and others know that this is at least a possible set-up should the occasion arise.
Regards
Ragnar in Iceland
Re: Green bearing question [Re: BadMoonRacer] #1198072
03/19/12 12:36 AM
03/19/12 12:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hi guys,
Regards
Ragnar in Iceland
Is it easier to get a green vs. an A7 bearing in iceland ?
Re: Green bearing question [Re: JohnRR] #1198073
03/19/12 02:34 AM
03/19/12 02:34 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
Since the tapered needs the other side to be adjustable, it cant be used ever with a green, plus the green, if used with the other side a tapered adjustable, wouldnt like the side load it would have to take to get the tapered roller seated properly. two greens, or two tapered. not one of each.
Re: Green bearing question [Re: cageman] #1198074
03/19/12 03:08 AM
03/19/12 03:08 AM
Wrong, as long as the Tapered Timken roller bearings are limited on how much side movement they can make, IE less than .005 the OP should be good. OP if it is more than .005 use another green bearing on the other side also
