Lower radiator hose is collapsing
#1197138
03/14/12 09:44 PM
03/14/12 09:44 PM
Posts: 1,487 STL
cdstl
STL
When I initially give the motor some gas the lower radiator hose on my 340 72 Cuda collapses and then opens back up. I went to NAPA and picked up a new hose and thought that it might have a spring inside, no luck. The new hose seems pretty pliant almost like the one on the car. Will the new hose collapse as well or who sells one with a spring inside? I am thinking about finding another hose at NAPA and pulling the spring out of it and putting it into the new hose. Any ideas?
Factory 26" radiator that flows 22GPM+, not sure what kind of water pump, RV etc.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Lower radiator hose is collapsing
[Re: cdstl]
#1197141
03/14/12 10:11 PM
03/14/12 10:11 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
""I am thinking about finding another hose at NAPA and pulling the spring out of it and putting it into the new hose."" That is how I did it too.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: cdstl]
#1197144
03/14/12 10:36 PM
03/14/12 10:36 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
I just pulled the spring out of an old hose and stuck it in the new one. I like the coat hanger idea too.
Scott
1969 Super Bee, 383/4 speed
[Re: bp27]
#1197145
03/14/12 10:46 PM
03/14/12 10:46 PM
Posts: 1,487 STL
cdstl
STL
I ordered the spring, $13.00 delivered. Still cheaper than buying a different hose just for the spring.
Thanks for the advise.
[Re: rick@laysons]
#1197147
03/15/12 04:38 PM
03/15/12 04:38 PM
Posts: 15,487 Florida
scratchnfotraction
Instead of bending one up out of a coat hanger, why not use a piece of stainless steel TIG welding rod?
I wouldn't want any more sources of corrosion in my cooling system that didn't absolutely HAVE to be there....just sayin...
this is best.
Found a few rusted coat hangers wraped up in the impeller before.
The wire eat a groove right thru the t-cover and leaked water into the crankcase.
[Re: scratchnfotraction]
#1197148
03/17/12 02:04 AM
03/17/12 02:04 AM
Posts: 270 Missouri
Big_E
Missouri
Stainless spring steel is the only way to go. I wanted one in stainless so I had to buy a minimum order. I had a original spring that I used as a guide. There are two major differences between "theirs" and "mine": • Nobody has the wire turned in on the ends. In my opinion the wire could rub thru the hose with enough heat cycles. • Mine is stainless steel. I did the magnet test right after I had them made to confirm they are stainless. If anyone is interested in one, pm me here. The original one is on the top, the new one-bottom.
[Re: BDW]
#1197150
03/17/12 06:14 PM
03/17/12 06:14 PM
Posts: 4,272 Morrow, OH
markz528
Morrow, OH
I made mine out of SS spring wire. Wrapped it around a wooden broom handle. Worked out great. Bought the spring material at McMaster Carr.
[Re: BDW]
#1197151
03/18/12 01:09 AM
03/18/12 01:09 AM
Posts: 270 Missouri
Big_E
Missouri
What diameter is it? Guessing from pic, 1.5"?
Correct, good guess.
