Lower radiator hose is collapsing #1197138
03/14/12 09:44 PM
03/14/12 09:44 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
When I initially give the motor some gas the lower radiator hose on my 340 72 Cuda collapses and then opens back up. I went to NAPA and picked up a new hose and thought that it might have a spring inside, no luck. The new hose seems pretty pliant almost like the one on the car. Will the new hose collapse as well or who sells one with a spring inside? I am thinking about finding another hose at NAPA and pulling the spring out of it and putting it into the new hose. Any ideas?
Factory 26" radiator that flows 22GPM+, not sure what kind of water pump, RV etc.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Lower radiator hose is collapsing [Re: cdstl] #1197139
03/14/12 09:50 PM
03/14/12 09:50 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
That's what I'd do.
Let me guess... the hose is NAPA part 7648? (or close to it, going from memory here).
-Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Lower radiator hose is collapsing [Re: 67SATisfaction] #1197140
03/14/12 10:05 PM
03/14/12 10:05 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
Re: Lower radiator hose is collapsing [Re: cdstl] #1197141
03/14/12 10:11 PM
03/14/12 10:11 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""I am thinking about finding another hose at NAPA and pulling the spring out of it and putting it into the new hose.""
That is how I did it too.
Re: Lower radiator hose is collapsing [Re: YO7_A66] #1197142
03/14/12 10:16 PM
03/14/12 10:16 PM
Fort Lauderdale, FL
Suregrip Offline
Suregrip  Offline
Fort Lauderdale, FL
Just take a piece of coat hanger and wind it up to the right shape...
Some people you just can't reach...
Re: Lower radiator hose is collapsing [Re: Suregrip] #1197143
03/14/12 10:33 PM
03/14/12 10:33 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I like the way you think.
Re: Lower radiator hose is collapsing [Re: cdstl] #1197144
03/14/12 10:36 PM
03/14/12 10:36 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I just pulled the spring out of an old hose and stuck it in the new one. I like the coat hanger idea too.
Scott
1969 Super Bee, 383/4 speed
Re: Lower radiator hose is collapsing [Re: bp27] #1197145
03/14/12 10:46 PM
03/14/12 10:46 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I ordered the spring, $13.00 delivered. Still cheaper than buying a different hose just for the spring.
Thanks for the advise.
Re: Lower radiator hose is collapsing [Re: cdstl] #1197146
03/15/12 01:25 PM
03/15/12 01:25 PM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
Instead of bending one up out of a coat hanger, why not use a piece of stainless steel TIG welding rod?
I wouldn't want any more sources of corrosion in my cooling system that didn't absolutely HAVE to be there....just sayin...
Re: Lower radiator hose is collapsing [Re: rick@laysons] #1197147
03/15/12 04:38 PM
03/15/12 04:38 PM
scratchnfotraction Offline
this is best.
Found a few rusted coat hangers wraped up in the impeller before.
The wire eat a groove right thru the t-cover and leaked water into the crankcase.
Re: Lower radiator hose is collapsing [Re: scratchnfotraction] #1197148
03/17/12 02:04 AM
03/17/12 02:04 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Stainless spring steel is the only way to go. I wanted one in stainless so I had to buy a minimum order. I had a original spring that I used as a guide.
There are two major differences between "theirs" and "mine":
• Nobody has the wire turned in on the ends. In my opinion the wire could rub thru the hose with enough heat cycles.
• Mine is stainless steel. I did the magnet test right after I had them made to confirm they are stainless.
If anyone is interested in one, pm me here.
The original one is on the top, the new one-bottom.
Re: Lower radiator hose is collapsing [Re: Big_E] #1197149
03/17/12 11:22 AM
03/17/12 11:22 AM
BDW Offline
BDW  Offline
What diameter is it? Guessing from pic, 1.5"?
Re: Lower radiator hose is collapsing [Re: BDW] #1197150
03/17/12 06:14 PM
03/17/12 06:14 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I made mine out of SS spring wire. Wrapped it around a wooden broom handle. Worked out great. Bought the spring material at McMaster Carr.
Re: Lower radiator hose is collapsing [Re: BDW] #1197151
03/18/12 01:09 AM
03/18/12 01:09 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Correct, good guess.
