torision bar install trouble?????? #1195219
03/11/12 07:25 PM
03/11/12 07:25 PM
phx
metalgod Offline OP
metalgod  Offline OP
phx
ok so now i have done this before how did i do it??? i have refered to he shop manual but still dont go, how do you align the lower control arm hex hole so that the bar slid sin cleanly, no matter what i do it will not line up, i have the front suspension hanging with no rebound bumper, i have moved the adjusting arm fully up and fully down and still the bar will not go in or at least will not line up to install cleanly, does the sterring linkage need to be dropped? whats is up?
Re: torision bar install trouble?????? [Re: metalgod] #1195220
03/11/12 07:30 PM
03/11/12 07:30 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Maybe you have L/R swapped around.
-Daty
Re: torision bar install trouble?????? [Re: metalgod] #1195221
03/11/12 08:10 PM
03/11/12 08:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Stock or Aftermarket bar Doug?.....confirm left and right, front/back if the bars are marked, also lay the bars on a flat surface together side by side to check the idex of the flats in relation to one another that they are l/r mirror images of each other, if your running factory style lower rubber bushings loosen the piviot nut on the LCA, some aftermarket bars the index of hex end front to rear may clock differently, requiring you to lift the lower arm slightly to engage the hex, esp the larger 1"+ bars, just make sure both sides of the vehicle are installed the same, tighten all the lower and upper control arm bolts/nuts with the car at ride height with the weight of the vehicle on the suspension
Re: torision bar install trouble?????? [Re: DAYCLONA] #1195222
03/11/12 08:25 PM
03/11/12 08:25 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i will probably get slammed for this statement. but i have see a LOT of experienced techs forget this step, me included.
is the arm that gets adjusted with the bolt loose? can you turn it all of the way down against the adjustment bolt with the bolt in the full down position? better yet you should be able to turn the arm by hand. a lot of techs just loosen the adjustment stud but forget to turn the arm down to the lower position.
you might have to loosen the bolt on the other side of the K member to let it fully bottom out against the adjustment bolt.
perception is 90% of reality
Re: torision bar install trouble?????? [Re: Mr T2U] #1195223
03/11/12 09:45 PM
03/11/12 09:45 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
After you back off the adjustment bolt, grab the arm hex with a channel lock pliers and twist it down to the adjustment bolt.
bar will line up then, that is with everything hanging down
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: torision bar install trouble?????? [Re: moparts] #1195224
03/12/12 01:18 AM
03/12/12 01:18 AM
phx
metalgod Offline OP
metalgod  Offline OP
phx
factory bar .092 left and right correct either end matter? one end has raised letters & #s adjustment arm either all up or all down no differance i will back off lower control arm mouting nut and se if it drops enough to line up it is off just slightly, thanks every one
Re: torision bar install trouble?????? [Re: metalgod] #1195225
03/12/12 10:31 AM
03/12/12 10:31 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Ahhh, if you torqued this nut down prior to installing the bars, chances are you have the socket out of alignment.
Re: torision bar install trouble?????? [Re: TC@HP2] #1195226
03/12/12 06:59 PM
03/12/12 06:59 PM
Mr T2U Offline
Mr T2U  Offline
just a reminder.
after you get the bar in. get the ride height close before tightening the front lower control arm bolt. this will keep the rubber from tearing.
