Re: torision bar install trouble??????
[Re: metalgod]
#1195221
03/11/12 08:10 PM
03/11/12 08:10 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Stock or Aftermarket bar Doug?.....confirm left and right, front/back if the bars are marked, also lay the bars on a flat surface together side by side to check the idex of the flats in relation to one another that they are l/r mirror images of each other, if your running factory style lower rubber bushings loosen the piviot nut on the LCA, some aftermarket bars the index of hex end front to rear may clock differently, requiring you to lift the lower arm slightly to engage the hex, esp the larger 1"+ bars, just make sure both sides of the vehicle are installed the same, tighten all the lower and upper control arm bolts/nuts with the car at ride height with the weight of the vehicle on the suspension
[Re: DAYCLONA]
#1195222
03/11/12 08:25 PM
03/11/12 08:25 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
i will probably get slammed for this statement. but i have see a LOT of experienced techs forget this step, me included. is the arm that gets adjusted with the bolt loose? can you turn it all of the way down against the adjustment bolt with the bolt in the full down position? better yet you should be able to turn the arm by hand. a lot of techs just loosen the adjustment stud but forget to turn the arm down to the lower position. you might have to loosen the bolt on the other side of the K member to let it fully bottom out against the adjustment bolt.
perception is 90% of reality
[Re: Mr T2U]
#1195223
03/11/12 09:45 PM
03/11/12 09:45 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
After you back off the adjustment bolt, grab the arm hex with a channel lock pliers and twist it down to the adjustment bolt.
bar will line up then, that is with everything hanging down
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#1195224
03/12/12 01:18 AM
03/12/12 01:18 AM
Posts: 2,134 phx
metalgod
phx
factory bar .092 left and right correct either end matter? one end has raised letters & #s adjustment arm either all up or all down no differance i will back off lower control arm mouting nut and se if it drops enough to line up it is off just slightly, thanks every one
[Re: metalgod]
#1195225
03/12/12 10:31 AM
03/12/12 10:31 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Ahhh, if you torqued this nut down prior to installing the bars, chances are you have the socket out of alignment.
[Re: TC@HP2]
#1195226
03/12/12 06:59 PM
03/12/12 06:59 PM
Mr T2U
just a reminder. after you get the bar in. get the ride height close before tightening the front lower control arm bolt. this will keep the rubber from tearing.
