67 Ply Mini Tub Pic's #1194922
03/11/12 03:11 AM
03/11/12 03:11 AM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
Im thinking of mini Tubbing my 67 Belvedere 1 street car. Im wanting to stay with Leaf springs and Im going to a Dana 60. I would like to see some Pic's so I could find the look Im after. I then can ask questions. Thanks and Im open to advice!!
All MOPARS & nothig else.
Re: 67 Ply Mini Tub Pic's [Re: Budman] #1194923
03/11/12 09:28 AM
03/11/12 09:28 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I don't have any digital pics of mine to post, but could get some today. The main things to watch are the ridge of the outter wheelwell. It curves in to clear the back of the quarter panel,but the factory left lots of extra room you'll need. Take the outter out,split it where it will interfere,and weld a patch in the gap. Also be warned that if you maximize the distance you move the springs themselves in,they will likely hit the lip around the gas tank(deadblow fix) and force modification of the gas filler tube in the spring area. If you measure and fit everything to the max you can get a 315-60-15 M/Tdrag radial in and still be able to slide your fingers past both sides of it. http://i355.photobucket.com/albums/r461/FriedDonuts/P1000654-1.jpg Not the best pic, but you get the idea.
Re: 67 Ply Mini Tub Pic's [Re: 67_Satellite] #1194924
03/11/12 06:24 PM
03/11/12 06:24 PM
Jamey Offline
Jamey  Offline
That looks great. I just bought a 67 gtx and will be doing the same. What did you do to get the exhaust out the back? I figure the only way would be a fuel cell. Do you have any underneath pics? Thanks
Re: 67 Ply Mini Tub Pic's [Re: Jamey] #1194925
03/11/12 08:52 PM
03/11/12 08:52 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
Thanks, your car is beautiful. What did you do about the trunk brackets? Do you have any pics of the inside of the trunk? Thanks again.
Re: 67 Ply Mini Tub Pic's [Re: Jamey] #1194926
03/12/12 08:50 AM
03/12/12 08:50 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
http://www.moparts.org/moparts/carshow/2002/2/welderboy.html
Old man's car...springs inboard, fuel cell, leaves plenty of room for 3" tailpipes...
no pics of trunk, sorry.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: 67 Ply Mini Tub Pic's [Re: Jamey] #1194927
03/12/12 05:34 PM
03/12/12 05:34 PM
I think you figure right. I initially ran it over the axle, between the spring and frame,and out behind the tire. This worked well on all of my tuning runs when I was alone in the car. With the wife and kid along there was enough suspension travel to "pinch" the pipe. I took the tailpipes off and installed turndowns until I can get a fuel cell in it and run the pipes straight out the back.
Re: 67 Ply Mini Tub Pic's [Re: Budman] #1194928
03/12/12 05:46 PM
03/12/12 05:46 PM
I'll have to get some digital pics to post, everything I have from that stage is in regular old fashioned prints. I did have to modify the trunk hinge brackets though. They are a 2 piece,spotwelded together affair. I drilled the spot welds out where the vertical portion makes the angle over to the stock wheelwell location. After the wheelwells were widened the remaining vertical portion of the hinge bracket lined up perfectly with the modified wheelwell. I also had to modify the rear seat frame to clear,but the seat cushion itself is unmodified.
Re: 67 Ply Mini Tub Pic's [Re: 67_Satellite] #1194929
03/12/12 09:18 PM
03/12/12 09:18 PM
Bartonville, Illinois
Fishyink Offline
Fishyink  Offline
Is the car black or dark green???
Shad Burkiett
Bartonville, IL
2014 Dodge Dart GT
08 Dodge Dakota TRX 4X4 4.7
08 Dodge Viper SRT-10
70 Plymouth Duster 408 6-barrel
Re: 67 Ply Mini Tub Pic's [Re: Budman] #1194930
03/13/12 04:14 PM
03/13/12 04:14 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Very easy to do, I did a mini-tub on my 67 Coronet a few years back. since then, I have added a stock width dana and am able to run 325x50x15 MT drag radials with plenty of room underneath. I posted these pics quite some time ago when this was a hot topic on here... the member on here by the name of Dragram also has done the same. Hope this helps.
Re: 67 Ply Mini Tub Pic's [Re: 67dodge67] #1194931
03/13/12 04:16 PM
03/13/12 04:16 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
...another....
Re: 67 Ply Mini Tub Pic's [Re: 67dodge67] #1194932
03/13/12 05:17 PM
03/13/12 05:17 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Dave in your last picture it looks like you just eliminated the "L" bracket for the bracket on the trunk springs and just welded it straight to the wider inner fender. Pretty nice.
Old Geezer Racing
Re: 67 Ply Mini Tub Pic's [Re: 67_Satellite] #1194933
03/13/12 06:11 PM
03/13/12 06:11 PM
Re: 67 Ply Mini Tub Pic's [Re: 67_Satellite] #1194934
03/13/12 06:15 PM
03/13/12 06:15 PM
Re: 67 Ply Mini Tub Pic's [Re: Fishyink] #1194935
03/13/12 06:23 PM
03/13/12 06:23 PM
It's a 90's Dodge truck or Dodge truck wheel color depending on what year and where it was applied.One name is "Moss green" and the other is "Woodland green" It has a gold colored pearl in it that jumps out in the sunlight. Here's a better look at it. http://www.youtube.com/watch?v=u8wb7JAM5...5-cMH7YDktoKEw=
Re: 67 Ply Mini Tub Pic's [Re: 67_Satellite] #1194936
03/13/12 09:56 PM
03/13/12 09:56 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
67Dodge67 did you stay with Leaf Springs?
Re: 67 Ply Mini Tub Pic's [Re: 67_Satellite] #1194937
03/13/12 10:15 PM
03/13/12 10:15 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
So why did you remove the entire inner wheel well
DOAH! What I had intended to ask, was "Why did you remove the outer wheel well", but you just explained that was to repair some rust issues. I had never seen anyone remove both sides of the wheel well tubs just to widen the inner tubs a couple of incehes. Thanks for clearing that up
Old Geezer Racing
Re: 67 Ply Mini Tub Pic's [Re: SCATPACK 1] #1194938
03/13/12 11:12 PM
03/13/12 11:12 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
You remove the inner wheel tub and trim the trunk floor to get the tub right up against the frame rail. Then you add in the section between the tubs to rejoin them. Move the leaf springs in board and voila instant room for large tires
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: 67 Ply Mini Tub Pic's [Re: SCATPACK 1] #1194939
03/13/12 11:15 PM
03/13/12 11:15 PM
The outter half needed some clearance surgery(see my first post at top)and there were some rust pinholes in the quarters. I sandblasted the back and laid a layer of fiberglass on it, then a skim of filler on top. No more pinholes.
Re: 67 Ply Mini Tub Pic's [Re: 67_Satellite] #1194940
03/15/12 10:14 PM
03/15/12 10:14 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
Did you guys relocate your Leaf Springs? Thanks for the pic's.
Re: 67 Ply Mini Tub Pic's [Re: Budman] #1194941
03/16/12 11:16 AM
03/16/12 11:16 AM
Yes, I did the standard notch the frame and put in boxes bit. Used a 15X10 weld draglite with the 7 1/2" backspaceing
