67 Ply Mini Tub Pic's
#1194922
03/11/12 03:11 AM
03/11/12 03:11 AM
Posts: 161 Logansport, Indiana
Budman
Logansport, Indiana
Im thinking of mini Tubbing my 67 Belvedere 1 street car. Im wanting to stay with Leaf springs and Im going to a Dana 60. I would like to see some Pic's so I could find the look Im after. I then can ask questions. Thanks and Im open to advice!!
All MOPARS & nothig else.
Re: 67 Ply Mini Tub Pic's
[Re: Budman]
#1194923
03/11/12 09:28 AM
03/11/12 09:28 AM
Posts: 1,021 Andrews,In. U.S.of A.
67_Satellite
I don't have any digital pics of mine to post, but could get some today. The main things to watch are the ridge of the outter wheelwell. It curves in to clear the back of the quarter panel,but the factory left lots of extra room you'll need. Take the outter out,split it where it will interfere,and weld a patch in the gap. Also be warned that if you maximize the distance you move the springs themselves in,they will likely hit the lip around the gas tank(deadblow fix) and force modification of the gas filler tube in the spring area. If you measure and fit everything to the max you can get a 315-60-15 M/Tdrag radial in and still be able to slide your fingers past both sides of it. http://i355.photobucket.com/albums/r461/FriedDonuts/P1000654-1.jpg Not the best pic, but you get the idea.
[Re: Jamey]
#1194925
03/11/12 08:52 PM
03/11/12 08:52 PM
Budman
Logansport, Indiana
Thanks, your car is beautiful. What did you do about the trunk brackets? Do you have any pics of the inside of the trunk? Thanks again.
[Re: Jamey]
#1194926
03/12/12 08:50 AM
03/12/12 08:50 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
http://www.moparts.org/moparts/carshow/2002/2/welderboy.htmlOld man's car...springs inboard, fuel cell, leaves plenty of room for 3" tailpipes... no pics of trunk, sorry.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: 67_Satellite]
#1194929
03/12/12 09:18 PM
03/12/12 09:18 PM
Posts: 193 Bartonville, Illinois
Fishyink
Is the car black or dark green???
Shad Burkiett Bartonville, IL
2014 Dodge Dart GT
08 Dodge Dakota TRX 4X4 4.7
08 Dodge Viper SRT-10
70 Plymouth Duster 408 6-barrel
[Re: Budman]
#1194930
03/13/12 04:14 PM
03/13/12 04:14 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Very easy to do, I did a mini-tub on my 67 Coronet a few years back. since then, I have added a stock width dana and am able to run 325x50x15 MT drag radials with plenty of room underneath. I posted these pics quite some time ago when this was a hot topic on here... the member on here by the name of Dragram also has done the same. Hope this helps.
[Re: 67dodge67]
#1194932
03/13/12 05:17 PM
03/13/12 05:17 PM
Posts: 1,505 TN
SCATPACK 1
TN
Dave in your last picture it looks like you just eliminated the "L" bracket for the bracket on the trunk springs and just welded it straight to the wider inner fender. Pretty nice.
Old Geezer Racing
[Re: 67_Satellite]
#1194937
03/13/12 10:15 PM
03/13/12 10:15 PM
Posts: 1,505 TN
SCATPACK 1
TN
So why did you remove the entire inner wheel well DOAH! What I had intended to ask, was "Why did you remove the outer wheel well", but you just explained that was to repair some rust issues. I had never seen anyone remove both sides of the wheel well tubs just to widen the inner tubs a couple of incehes. Thanks for clearing that up
Old Geezer Racing
[Re: SCATPACK 1]
#1194938
03/13/12 11:12 PM
03/13/12 11:12 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
You remove the inner wheel tub and trim the trunk floor to get the tub right up against the frame rail. Then you add in the section between the tubs to rejoin them. Move the leaf springs in board and voila instant room for large tires
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
