Anyone try Bare Metal Foil for chrome plate repairs?
#1191269
03/04/12 09:41 PM
03/04/12 09:41 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
Anyone try this and like it? Or does it look like a piece of tape?
Still looking for LM29H1B415501, '71 Demon 340
Re: Anyone try Bare Metal Foil for chrome plate repairs?
[Re: dvw]
#1191271
03/05/12 04:59 AM
03/05/12 04:59 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I've used that stuff on models before. You'd want to use a stronger adhesive like 3M Super 77 and get the edges protected with a wax or something, it's convincing on a small scale but definitely not weather-grade. It should work well on interior dash chrome.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: DynoDave]
#1191278
03/05/12 08:39 PM
03/05/12 08:39 PM
PAULS_340
Motown, Mi
chromedome426, there are a number of responses. What did you use? The Bare Metal Foil? If so, that's exactly what I want.
[Re: PAULS_340]
#1191279
03/05/12 10:43 PM
03/05/12 10:43 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I used percisely the HobbyTown bare metal foil in your photo to 'freshen up' a small part in my instrument cluster.
There was some leftover old chrome plating on the plastic piece, but I scotchbrited it smooth and cleaned with alcohol before applying the foil. It looked fabulous for 3 months, now the underlying old plating I left on the part is delaminating under the new baremetal foil and telescoping through it.
Advice: I think it would work, but get rid of ALL the old plating and apply only to a fresh surface.
Best, -Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: PAULS_340]
#1191280
03/06/12 02:24 AM
03/06/12 02:24 AM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
I used it on about 80% of my 68 dash refresh....I'm too fat fingered to get it around the turn signal bezels. stuff works very well for what is....on something larger than dash bezels, NO WAY. not unless you sanded what's underneath with a magnifying glass and a micrometer. This stuff picks up even the slightest imperfection under it because its super super thin...which is why it conforms so well and works so well on small pieces. bare metal foil dash restoI used exact same stuff you posted.
[Re: PAULS_340]
#1191283
03/06/12 10:27 AM
03/06/12 10:27 AM
Posts: 409 PEI Canada
chromedome426
PEI Canada
I used (chrome) Bare Metal Foil because thats what I had on hand. Next time I would like to try the (ultra chrome) Bare Metal Foil.
