Anyone try Bare Metal Foil for chrome plate repairs? #1191269
03/04/12 09:41 PM
03/04/12 09:41 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Anyone try this and like it? Or does it look like a piece of tape?
Still looking for LM29H1B415501, '71 Demon 340
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: PAULS_340] #1191270
03/04/12 11:33 PM
03/04/12 11:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Works good on model cars. I'd bet it would work in small areas as well.
Doug
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: dvw] #1191271
03/05/12 04:59 AM
03/05/12 04:59 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
I've used that stuff on models before. You'd want to use a stronger adhesive like 3M Super 77 and get the edges protected with a wax or something, it's convincing on a small scale but definitely not weather-grade. It should work well on interior dash chrome.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: PAULS_340] #1191272
03/05/12 05:02 AM
03/05/12 05:02 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I thought they have vinyl wrap now that looks like chrome?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: HealthServices] #1191273
03/05/12 05:04 AM
03/05/12 05:04 AM
So Cal
So Cal
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: PAULS_340] #1191274
03/05/12 05:36 AM
03/05/12 05:36 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: 1_WILD_RT] #1191275
03/05/12 09:10 AM
03/05/12 09:10 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Or
http://www.ebay.com/itm/Silver-Chrome-Mi...mtr#ht_968wt_85
I've also used aluminum duct tape for some things. It polishes up like chrome.
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: bobs66440] #1191276
03/05/12 11:27 AM
03/05/12 11:27 AM
PEI Canada
chromedome426 Offline
PEI Canada
I used it on my dash bezels. Looks a lot better than silver/chrome paint.
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: chromedome426] #1191277
03/05/12 08:22 PM
03/05/12 08:22 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Nice work chromedome.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: DynoDave] #1191278
03/05/12 08:39 PM
03/05/12 08:39 PM
Motown, Mi
P
P
Motown, Mi
chromedome426, there are a number of responses. What did you use? The Bare Metal Foil? If so, that's exactly what I want.
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: PAULS_340] #1191279
03/05/12 10:43 PM
03/05/12 10:43 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
I used percisely the HobbyTown bare metal foil in your photo to 'freshen up' a small part in my instrument cluster.
There was some leftover old chrome plating on the plastic piece, but I scotchbrited it smooth and cleaned with alcohol before applying the foil. It looked fabulous for 3 months, now the underlying old plating I left on the part is delaminating under the new baremetal foil and telescoping through it.
Advice: I think it would work, but get rid of ALL the old plating and apply only to a fresh surface.
Best, -Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: PAULS_340] #1191280
03/06/12 02:24 AM
03/06/12 02:24 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I used it on about 80% of my 68 dash refresh....I'm too fat fingered to get it around the turn signal bezels. stuff works very well for what is....on something larger than dash bezels, NO WAY. not unless you sanded what's underneath with a magnifying glass and a micrometer. This stuff picks up even the slightest imperfection under it because its super super thin...which is why it conforms so well and works so well on small pieces.
bare metal foil dash resto
I used exact same stuff you posted.
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: Pool Fixer] #1191281
03/06/12 02:28 AM
03/06/12 02:28 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
finished product. Not what you would get from a pro, but for a driver, more than presentable.
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: Pool Fixer] #1191282
03/06/12 02:29 AM
03/06/12 02:29 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
closer shot
Re: Anyone try Bare Metal Foil for chrome plate repairs? [Re: PAULS_340] #1191283
03/06/12 10:27 AM
03/06/12 10:27 AM
PEI Canada
PEI Canada
I used (chrome) Bare Metal Foil because thats what I had on hand. Next time I would like to try the (ultra chrome) Bare Metal Foil.
