Re: 8 3/4 pig removal
[Re: BlenheimBoy]
#1187453
02/28/12 01:04 AM
02/28/12 01:04 AM
Posts: 959 Cincinnati,Ohio
jcastle1
Cincinnati,Ohio
jack up rear-end, place jack stands under rear-end, remove driveshaft, remove wheels, remove drums, un-bolt axles, pull axles out about 6 inches(may need a hard pull), place bucket under the pig,to catch foul smelling fluid, un-bolt the pig. pry pig away from housing with small screwdriver. lower pig to ground, pig is heavy
[Re: jcastle1]
#1187454
02/28/12 03:53 AM
02/28/12 03:53 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
jcastle1 - you need to write your own line of shop manuals like Chiltons or Haynes. That was as perfectly written as instructions ever need be for anyone who can work on cars.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: jcastle1]
#1187455
02/28/12 04:58 AM
02/28/12 04:58 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
THEN... Step into bucket of gear lube. Slip and spill contents on shop floor. Bruise head on concrete. Get gear oil in hair.
[Re: Rick_Ehrenberg]
#1187458
02/28/12 01:26 PM
02/28/12 01:26 PM
Posts: 592 Sullivan, Ohio
Max Wedge Savoy
Sullivan, Ohio
Yeah. Ancient SG lube is a close relative of Skunk juice. Don't ask how many "shampoos" I've taken in that s**t.
Quick addendum for instructions:
Flip the drum around, install lug nuts 2 or 3 turns, drum works as zero-buck slide hammer to pop axles loose.
Rick
I still have a couple little bottles of additive if you would like to rekindle that lovely scent!
[Re: jcastle1]
#1187459
02/28/12 02:17 PM
02/28/12 02:17 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
wear clothes you can trow away...long sleevs, long pants, rubber gloves and after you unbolt it, pry it out and let all the goo drain... I have also pumped the gear oil out via the fill hole, but you will still have plenty left. Then get the jack ready, slide it forward then let it down SLOW, or it will roll off.
[Re: Mr.Yuck]
#1187460
02/28/12 02:29 PM
02/28/12 02:29 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Dont forget to have a glass patio table nearby to hold the removed pig.
Also if its a virgin pig, and never been pulled, there may be copper crush washers on under the nuts, this makes removing the pig a bit more difficult.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: BlenheimBoy]
#1187462
02/28/12 03:49 PM
02/28/12 03:49 PM
Challenger 1
Cincinnati, Ohio
I try to stay away from it coming out, I just let it hit the concrete on the way out. Then roll it out from under the truck and pick it up with my engine crane. That way I don't get much smelly stuff on me. When it comes time to go back in I have to use my trans jack. Jack the back of the truck up and under it goes. Took it out and put it back in by myself. Stay out of it's way and you won't get hurt.
[Re: jcastle1]
#1187463
02/28/12 09:55 PM
02/28/12 09:55 PM
Posts: 5,894 Florida
Locomotion
jack up rear-end, place jack stands under rear-end, remove driveshaft, remove wheels, remove drums, un-bolt axles, pull axles out about 6 inches(may need a hard pull), place bucket under the pig,to catch foul smelling fluid, un-bolt the pig. small pry pig away from housing with small screwdriver. lower pig to ground, pig is heavy
You forgot to remove the pinion snubber. It will make it a little lighter.
I try to leave one nut loose near the top for safety, put a screwdriver somewhere around the sides and just let the fluid drain for a while. I've balanced it in a wide-pad floor jack during removal and installation, but you gotta be very careful trying to balance it and work the floor jack at the same time.
[Re: Locomotion]
#1187464
02/29/12 12:58 AM
02/29/12 12:58 AM
Posts: 4,427 Michigan
MarkZ
Worthy
Worthy
I guess I'm the only guy that likes the smell of gear oil. Must be something wrong with me.... Anyhow, to add to the advice, leave the top nut in place, but unthreaded to the end of the stud, and pry up on the front of the pig until the seal breaks. This is an easy way to drain the housing without having to worry about the pig falling. The higher you get the back end of the car up the more fluid you'll get out of the housing.
#1187467
02/29/12 03:00 AM
02/29/12 03:00 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Rick
Yup! Been doing that one since I was a Cub...
[Re: BlenheimBoy]
#1187476
03/05/12 09:55 PM
03/05/12 09:55 PM
Posts: 21,827 Kirkland, Washington
Pacnorthcuda
Passenger side shaft removed. Pig pulled out. Fuild was not smelly, rearend has not been in use in long time. Thx for the instructions and help Moparts members. Taking parts to get acid dipped and save $$$ to buy rebuild parts.
Thx again Blenheim-Boy
"acid dipped" ?
[Re: BlenheimBoy]
#1187478
03/06/12 10:23 PM
03/06/12 10:23 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
That hardly seems fair. You're not getting the full experience!
