8 3/4 pig removal #1187452
02/28/12 12:36 AM
02/28/12 12:36 AM
Blenheim, Ontario Canada
BlenheimBoy Offline OP
I have never removed gears out of 8 3/4 rearend.
Any links or instructions on removal?
thx
Bill
Blenheim-Boy
Re: 8 3/4 pig removal [Re: BlenheimBoy] #1187453
02/28/12 01:04 AM
02/28/12 01:04 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
jack up rear-end,
place jack stands under rear-end,
remove driveshaft,
remove wheels,
remove drums,
un-bolt axles,
pull axles out about 6 inches(may need a hard pull),
place bucket under the pig,to catch foul smelling fluid,
un-bolt the pig.
pry pig away from housing with small screwdriver.
lower pig to ground,
pig is heavy
Re: 8 3/4 pig removal [Re: jcastle1] #1187454
02/28/12 03:53 AM
02/28/12 03:53 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
jcastle1 - you need to write your own line of shop manuals like Chiltons or Haynes. That was as perfectly written as instructions ever need be for anyone who can work on cars.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 8 3/4 pig removal [Re: jcastle1] #1187455
02/28/12 04:58 AM
02/28/12 04:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
jack up rear-end,
remove driveshaft,
remove wheels,
remove drums,
un-bolt axles,
un-bolt the pig.
pig is heavy
THEN...
Step into bucket of gear lube.
Slip and spill contents on shop floor. Bruise head on concrete.
Get gear oil in hair.
Re: 8 3/4 pig removal [Re: Kern Dog] #1187456
02/28/12 12:37 PM
02/28/12 12:37 PM
dogdays Offline
dogdays  Offline
Then get gear oil on hands trying to clean it up and discover that you now can TASTE the stuff! Seems to soak through skin or something.
R.
Re: 8 3/4 pig removal [Re: dogdays] #1187457
02/28/12 01:06 PM
02/28/12 01:06 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Yeah. Ancient SG lube is a close relative of Skunk juice. Don't ask how many "shampoos" I've taken in that s**t.
Quick addendum for instructions:
Flip the drum around, install lug nuts 2 or 3 turns, drum works as zero-buck slide hammer to pop axles loose.
Rick
Re: 8 3/4 pig removal [Re: Rick_Ehrenberg] #1187458
02/28/12 01:26 PM
02/28/12 01:26 PM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
Rick
I still have a couple little bottles of additive if you would like to rekindle that lovely scent!
Re: 8 3/4 pig removal [Re: jcastle1] #1187459
02/28/12 02:17 PM
02/28/12 02:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
jack up rear-end,
remove driveshaft,
remove wheels,
remove drums,
un-bolt axles,
un-bolt the pig.
pig is heavy
wear clothes you can trow away...long sleevs, long pants, rubber gloves and after you unbolt it, pry it out and let all the goo drain... I have also pumped the gear oil out via the fill hole, but you will still have plenty left. Then get the jack ready, slide it forward then let it down SLOW, or it will roll off.
Coming soon!!!!
Re: 8 3/4 pig removal [Re: Mr.Yuck] #1187460
02/28/12 02:29 PM
02/28/12 02:29 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Dont forget to have a glass patio table nearby to hold the removed pig.
Also if its a virgin pig, and never been pulled, there may be copper crush washers on under the nuts, this makes removing the pig a bit more difficult.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 8 3/4 pig removal [Re: jcastle1] #1187461
02/28/12 02:36 PM
02/28/12 02:36 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'd remove the axle completelly to keep safe the inner oil seal
Re: 8 3/4 pig removal [Re: BlenheimBoy] #1187462
02/28/12 03:49 PM
02/28/12 03:49 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I try to stay away from it coming out, I just let it hit the concrete on the way out. Then roll it out from under the truck and pick it up with my engine crane. That way I don't get much smelly stuff on me.
When it comes time to go back in I have to use my trans jack.
Jack the back of the truck up and under it goes.
Took it out and put it back in by myself.
Stay out of it's way and you won't get hurt.
Re: 8 3/4 pig removal [Re: jcastle1] #1187463
02/28/12 09:55 PM
02/28/12 09:55 PM
Locomotion Offline
Locomotion  Offline
jack up rear-end,
remove driveshaft,
remove wheels,
remove drums,
un-bolt axles,
un-bolt the pig.
small pry pig away from housing with small screwdriver.
pig is heavy
You forgot to remove the pinion snubber.
It will make it a little lighter.
I try to leave one nut loose near the top for safety, put a screwdriver somewhere around the sides and just let the fluid drain for a while. I've balanced it in a wide-pad floor jack during removal and installation, but you gotta be very careful trying to balance it and work the floor jack at the same time.
Re: 8 3/4 pig removal [Re: Locomotion] #1187464
02/29/12 12:58 AM
02/29/12 12:58 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I guess I'm the only guy that likes the smell of gear oil.
Must be something wrong with me....
Anyhow, to add to the advice, leave the top nut in place, but unthreaded to the end of the stud, and pry up on the front of the pig until the seal breaks. This is an easy way to drain the housing without having to worry about the pig falling. The higher you get the back end of the car up the more fluid you'll get out of the housing.
Re: 8 3/4 pig removal [Re: Locomotion] #1187465
02/29/12 12:59 AM
02/29/12 12:59 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I can't believe I forgot about the friggin' pinion snubber!
Re: 8 3/4 pig removal [Re: jcastle1] #1187466
02/29/12 01:07 AM
02/29/12 01:07 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Dispose of old stinky diff fluid to MarkM,He likes it!
Re: 8 3/4 pig removal [Re: Rick_Ehrenberg] #1187467
02/29/12 03:00 AM
02/29/12 03:00 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Rick
Yup! Been doing that one since I was a Cub...
Re: 8 3/4 pig removal [Re: Sixgun] #1187468
02/29/12 04:36 AM
02/29/12 04:36 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I learned that trick from Rick himself. THANKS Mopar Action!
Re: 8 3/4 pig removal [Re: Kern Dog] #1187469
02/29/12 09:38 AM
02/29/12 09:38 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I don't have any pics, but I made a small platform out of wood and mounted it to my floorjack for the "pig" to rest on when your ready to pull it out. Basically it was 3/4" plywood with chocks on the sides to keep the pig from rolling. Worked for me.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: 8 3/4 pig removal [Re: bobbyb] #1187470
02/29/12 11:19 AM
02/29/12 11:19 AM
New York
jagrunt551 Offline
jagrunt551  Offline
New York
This great information and great photos. Now how does it all go back together???
Re: 8 3/4 pig removal [Re: bobbyb] #1187471
02/29/12 11:33 AM
02/29/12 11:33 AM
NY usa
540challenger Offline
NY usa
All great advise but one more thing.
After you remove the center section check to make sure the thrust spacer is still inside the carrier.
Sometimes they are held in place by a roll pin and when you remove the axles they drop into the housing.
Check now beofore you reinstall your axles and wonder why you have too much end play.
