ATF+4 In an 833?
#118677
09/10/08 02:52 PM
09/10/08 02:52 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
Transmission guys-thoughts? Isn't 4 designed for higher temps?
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
Re: ATF+4 In an 833?
[Re: Paul_Fancsali]
#118680
09/10/08 03:04 PM
09/10/08 03:04 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
My advise is don't do it Your 833 is better protected by gear oil. Also had a problem years ago shifting using atf in a HD 3 spd changed over to gear oil problem solved
But be sure to use GL-4 lube and NOT GL-5! Synchros will work better, last longer
[Re: Paul_Fancsali]
#118682
09/10/08 07:51 PM
09/10/08 07:51 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
100%
80W90 gear oil works great. ATF is for automatics.
[Re: kenworth_goose]
#118684
09/11/08 04:18 PM
09/11/08 04:18 PM
Posts: 326 Davenport, IA
70shaker
Davenport, IA
Use Penzoil Synchromesh gear oil and the trans will shift like butter.
Ex Hemi Racer 70 Challenger Hemi 4 speed clone
[Re: DaytonaTurbo]
#118687
09/12/08 12:13 PM
09/12/08 12:13 PM
RangerDan440
thanks guys, especially for the ATF+4 info page
Ive always used ATF in my 833 and never had a problem, always shifts nice; I didnt know if the the +4 was much different than +3 though, and I thought if it was designed for higher temp use (thinner, maybe less viscous) than maybe I would use gear oil or a differnt ATF.
Im putting a new clutch in this weekend and while the trans is out, Im going to go through it, change the fluid and seals, etc
[Re: DaytonaTurbo]
#118689
09/12/08 12:53 PM
09/12/08 12:53 PM
Posts: 4,573 ...gently down the stream
LAR_414
I've heard good things about GM Synchromesh for the fwd 5sp's, but for an 833, why not get Passon's mystery super lube?
I wonder if Jamie can chime in on the benefits of his lube stuff?
[Re: In_The_Pink]
#118692
09/12/08 09:09 PM
09/12/08 09:09 PM
100%
I am in this camp////
[Re: 70shaker]
#118694
09/14/08 01:53 PM
09/14/08 01:53 PM
Posts: 1,014 LEE, MASS
TOMRR
LEE, MASS
