ATF+4 In an 833? #118677
09/10/08 02:52 PM
09/10/08 02:52 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
Transmission guys-thoughts? Isn't 4 designed for higher temps?
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: ATF+4 In an 833? [Re: RangerDan440] #118678
09/10/08 03:01 PM
09/10/08 03:01 PM
P
Paul_Fancsali Offline
P
My advise is don't do it Your 833 is better protected by gear oil. Also had a problem years ago shifting using atf in a HD 3 spd changed over to gear oil problem solved
Re: ATF+4 In an 833? [Re: RangerDan440] #118679
09/10/08 03:01 PM
09/10/08 03:01 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
A little ATF+4 Info!
Re: ATF+4 In an 833? [Re: Paul_Fancsali] #118680
09/10/08 03:04 PM
09/10/08 03:04 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
But be sure to use GL-4 lube and NOT GL-5! Synchros will work better, last longer
Re: ATF+4 In an 833? [Re: Pacnorthcuda] #118681
09/10/08 05:05 PM
09/10/08 05:05 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
ATF worked for my dads challenger he bought new for 112,000 miles. We rebuilt the tranny 2 years ago - it needed a 1-2 shift fork, seals, bearings and gaskets.
guess what went back in it? ATF!
Jamie Passon makes a fluid on his own that I;d recommend as well.
Re: ATF+4 In an 833? [Re: Paul_Fancsali] #118682
09/10/08 07:51 PM
09/10/08 07:51 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
100%
80W90 gear oil works great. ATF is for automatics.
Re: ATF+4 In an 833? [Re: RangerDan440] #118683
09/10/08 08:44 PM
09/10/08 08:44 PM
ky.
K
kenworth_goose Offline
K
ky.
ATF works much better than gear oil. Add a quart of lucas.
Re: ATF+4 In an 833? [Re: kenworth_goose] #118684
09/11/08 04:18 PM
09/11/08 04:18 PM
Davenport, IA
70shaker Offline
70shaker  Offline
Davenport, IA
Use Penzoil Synchromesh gear oil and the trans will shift like butter.
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
Re: ATF+4 In an 833? [Re: 70shaker] #118685
09/11/08 05:22 PM
09/11/08 05:22 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Re: ATF+4 In an 833? [Re: Cudajon] #118686
09/12/08 12:56 AM
09/12/08 12:56 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've heard good things about GM Synchromesh for the fwd 5sp's, but for an 833, why not get Passon's mystery super lube?
Re: ATF+4 In an 833? [Re: DaytonaTurbo] #118687
09/12/08 12:13 PM
09/12/08 12:13 PM
thanks guys, especially for the ATF+4 info page
Ive always used ATF in my 833 and never had a problem, always shifts nice; I didnt know if the the +4 was much different than +3 though, and I thought if it was designed for higher temp use (thinner, maybe less viscous) than maybe I would use gear oil or a differnt ATF.
Im putting a new clutch in this weekend and while the trans is out, Im going to go through it, change the fluid and seals, etc
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
Re: ATF+4 In an 833? [Re: 70shaker] #118688
09/12/08 12:52 PM
09/12/08 12:52 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
How is it when it's cold out?
DId you Change from one type of fluid to this?
Re: ATF+4 In an 833? [Re: DaytonaTurbo] #118689
09/12/08 12:53 PM
09/12/08 12:53 PM
LAR_414 Offline
LAR_414  Offline
I wonder if Jamie can chime in on the benefits of his lube stuff?
Re: ATF+4 In an 833? [Re: LAR_414] #118690
09/12/08 03:01 PM
09/12/08 03:01 PM
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Here is some info on Amsoil's Synchromesh trans fluid.
Click on the MTF fluid for more info.
Re: ATF+4 In an 833? [Re: Spike] #118691
09/12/08 09:04 PM
09/12/08 09:04 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have been using the Red Line MTL and no problems. Here is their web page:
http://www.redlineoil.com/products_gearlubricants.asp?categoryID=7
Re: ATF+4 In an 833? [Re: In_The_Pink] #118692
09/12/08 09:09 PM
09/12/08 09:09 PM
100%
I am in this camp////
Re: ATF+4 In an 833? #118693
09/13/08 02:53 AM
09/13/08 02:53 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
I have always mixed my own, about 1/2 80-90 and and 1/2 ATF. If its to slippery the stop rings don't stop correctly and wear a little faster. I've been doing this since the '60's and no trouble at all, what the other guys are selling is nothing new either.
Re: ATF+4 In an 833? [Re: 70shaker] #118694
09/14/08 01:53 PM
09/14/08 01:53 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
