Is there a 'modern' version of the MP .528 cam? #118646
09/10/08 01:46 PM
09/10/08 01:46 PM
St. Catharines, ON
N
NewMemberAgain Offline OP
super street
super street
N
St. Catharines, ON
I am in the process of de-racing my dart sport, and wanted to change a few things around.
One of them is the camshaft. I really like the spec's of this camshaft, and has been proven time and time again. I just wondered if a newer cam exists.
Streetable is the key, along with the long 112 centerline makes for good idle and vacuum.
Or have I just sold myself on this cam?
Bryan
73' Dart Sport w/440
Re: Is there a 'modern' version of the MP .528 cam? [Re: NewMemberAgain] #118647
09/10/08 01:59 PM
09/10/08 01:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The MP .528 is already ground on a 112 centerline, so I don't see what else modernizing it would do. It's not the most modern camshaft, but it's proven time and again both on the dyno and on the street.
Re: Is there a 'modern' version of the MP .528 cam? [Re: NewMemberAgain] #118648
09/10/08 02:02 PM
09/10/08 02:02 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Call Tim at Bullet racing cams he has a Purple Shaft replacement ground for a .904 lifter [Email]270@.020[/Email] [Email]243@.050[/Email] .548 lift with 1.5 rocker. I've run it in a 360 street car and really liked it. Pulls good from 2500 up and idles nice with decent vaccum. Went 11's with an 11" converter,3.91 gear 28" tire Non quench sb with factory heads in and a body. Mid 11's with a 4200 converter and 4.30 gears. Lash is .016"
Re: Is there a 'modern' version of the MP .528 cam? [Re: NewMemberAgain] #118649
09/10/08 02:42 PM
09/10/08 02:42 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
I guess I am really trying to get my head around the term "modern" when it applies to camshafts for overhead valve pushrod engines. Seems to me a lot of the "modern" designs have a high rate of failure ? Now that the manufacturers can build overhead cam engines, why stick with Paleozoic technology ?
I didn't know that the Chevy small-block camshaft introduced in '55 was "kinda" a copy of the Porsche camshafts of the day, until a couple of years ago. And, the rest followed Chevy.
Two camshafts have impressed me - the Chrysler purple shaft jobs, and the Lunatis . Press on !
Re: Is there a 'modern' version of the MP .528 cam? [Re: NewMemberAgain] #118650
09/10/08 03:28 PM
09/10/08 03:28 PM
AndyF Offline
AndyF  Offline
The .528 works great. It has a bunch of lash and is a fairly slow ramp but so what, it works. I'm not so sure that you want a modern lobe anyway for a daily driver if by modern lobe you mean tight lash, fast ramp, quick valve action, etc.
Re: Is there a 'modern' version of the MP .528 cam? [Re: AndyF] #118651
09/10/08 03:42 PM
09/10/08 03:42 PM
Iowa
clarkj Offline
clarkj  Offline
Iowa
I had the .528 in a 360 and absolutely loved it. Great on the street and it pulled hard right from idle with only a modest converter.
Re: Is there a 'modern' version of the MP .528 cam? [Re: AndyF] #118652
09/10/08 03:48 PM
09/10/08 03:48 PM
St. Catharines, ON
N
super street
super street
N
St. Catharines, ON
Thanks for replying guys.
I just really wanted to hear some feedback, even though I feel I am going to get it.
This 'might' change things, but I forgot to give my motor combo.
440 + .55 Ross 10:1 pistons, (really about 9.75)
Stock Eddy Heads (84cc)
Dual Quad Eddy Intake
Dual Carter 625's
OLD CPPA 1 3/4 " headers - NOTE Will goto Tri Y's
2.5" Exhaust into TA/AAR mufflers w/ tips
4.56's with 28 x 11.5 MT ET Streets
Over winter 3.55, or 3.91??
MSD 6AL
Stock MP Distributor
Car has 8 point roll bar in it now, but over the winter will cut out the door bars, and horizontal bar in the hoop, and put back the rest of the interior again.
Maybe, I will start to drive it again after all the work
Re: Is there a 'modern' version of the MP .528 cam? [Re: NewMemberAgain] #118653
09/10/08 04:06 PM
09/10/08 04:06 PM
AndyF Offline
AndyF  Offline
Sounds great, you'll really like it once you swap out the 4.56 gears for some 3.55's.
Re: Is there a 'modern' version of the MP .528 cam? [Re: AndyF] #118654
09/10/08 04:40 PM
09/10/08 04:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no need, it has a good centerline unlike the 484 and 509 so it will idle good and pull plenty of vacuum. Not to mention is much more reponsive at lower rpms. Your set-up should run good. try 3.91's
Re: Is there a 'modern' version of the MP .528 cam? [Re: IronWolf] #118655
09/10/08 04:54 PM
09/10/08 04:54 PM
that's been from the lack of zddp (zinc) & other needed additives in the oils.
Re: Is there a 'modern' version of the MP .528 cam? [Re: RapidRobert] #118656
09/10/08 10:27 PM
09/10/08 10:27 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Just get it over with and throw in the 528 cam, you'll love it. My truck in my signature had a $300 440 in it with the 528 cam. It ran a 12.19 with a 1.595 60ft. time. 10" turboaction converter and 4.56 gears. It was picking the fronts of the ground 6-8" on launch. The cam make unreal torque and idles almost like a stocker. I can't see a downside on your application, you'll like the cam, now go throw it in. Dave
Ordered it up! [Re: quickd100] #118657
09/11/08 02:43 PM
09/11/08 02:43 PM
St. Catharines, ON
N
super street
super street
N
St. Catharines, ON
Well I got off my virtual wallet, I mean real wallet and ordered the camshaft.
The description is a little vague to say the least, but does this come with lifters. It does not say either way???
Bryan
Re: Ordered it up! [Re: NewMemberAgain] #118658
09/11/08 03:27 PM
09/11/08 03:27 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It comes with lifters. In fact the cam isn't even sold separately...it HAS to be bought with the lifters.
Re: Ordered it up! [Re: ZIPPY] #118659
09/11/08 04:04 PM
09/11/08 04:04 PM
St. Catharines, ON
N
super street
super street
N
St. Catharines, ON
Thanks Zippy!
Bryan
