Dash lights #1178750
02/15/12 08:52 AM
02/15/12 08:52 AM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
My dash lights on my 71 B seem a little low in brightness, not bad, but I always wished they were brighter. Do they make a higher watt bulb, and is it OK to use them?
Re: Dash lights [Re: DANA60] #1178751
02/15/12 02:39 PM
02/15/12 02:39 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Run your headlights through relays directly off the battery and get better headlights and brighter dash lights at the same time. Plus its easier than pulling the dash to get at some of those bulbs.
Re: Dash lights [Re: CYACOP] #1178752
02/15/12 02:43 PM
02/15/12 02:43 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
x2
(Although, the LEDs in my dash are a little brighter than the incandescents and don't put out as much heat...)
Re: Dash lights [Re: MoparMarq] #1178753
02/16/12 12:10 PM
02/16/12 12:10 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
x2
I've upgraded all my old cars to LED's...they're brighter and they produce very little heat...you have to get all the right colors though, meaning get the same color LED as the lens its shining thru (Green for Turn Signal's, Blue for Hi-Beam Indicator, Red for Warning lights, etc...) and buy the nice ones...I got the cheepies off of ebay and ended up replacing them all because they sucked...I've spend several hundred dollars alone on LED bulbs and couldn't be happier...especially in the side of the console where I use to burn my legs all the time.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Dash lights [Re: DANA60] #1178754
02/16/12 07:09 PM
02/16/12 07:09 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Buy your LED bulbs from superbrightleds.com BUT do not put the high intensity bulbs in the turn signal and high beam indicators. They are WAY too bright. My high beam indicator is so bright that it blinds me at night.
Use LEDs in the same color as the lens. If you put a white LED behind a blue lens you will get a bright white light with a wee tiny bit of blue tint.
- Stu Harmon
Re: Dash lights [Re: feets] #1178755
02/16/12 07:13 PM
02/16/12 07:13 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
SuperBrightLED has a wide selection. Surfing their website was sometimes confusing, but now I'm used to it.
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Dash lights [Re: 67SATisfaction] #1178756
02/16/12 08:09 PM
02/16/12 08:09 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
all my lamps are lit on the duster,and they seem to be bright enough.now the 61 is another story.im going to try and get them going this spring,way cool luminesent lighting,if they work.
Re: Dash lights [Re: feets] #1178757
02/17/12 12:52 AM
02/17/12 12:52 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
thats where I got mine as well...
