Re: Dash lights
[Re: CYACOP]
#1178752
02/15/12 02:43 PM
02/15/12 02:43 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Run your headlights through relays directly off the battery and get better headlights and brighter dash lights at the same time. Plus its easier than pulling the dash to get at some of those bulbs.
x2
(Although, the LEDs in my dash are a little brighter than the incandescents and don't put out as much heat...)
Re: Dash lights
[Re: DANA60]
#1178754
02/16/12 07:09 PM
02/16/12 07:09 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Buy your LED bulbs from superbrightleds.com BUT do not put the high intensity bulbs in the turn signal and high beam indicators. They are WAY too bright. My high beam indicator is so bright that it blinds me at night.
Use LEDs in the same color as the lens. If you put a white LED behind a blue lens you will get a bright white light with a wee tiny bit of blue tint.
