How do i test my fuel sending unit? #1176241
02/10/12 10:15 PM
02/10/12 10:15 PM
Columbus, OH
Spanky Offline OP
Spanky  Offline OP
Columbus, OH
All gauges aren't working on my 71 Road Runner (except the amp meter, it works okay). Pulled the sending unit to test it with a cheap harbor freight multimeter. What range should i set it to & what should it read?
I set it to 2000 ohms and it appears to be reading from about 15-73 throughout the float range. It's the original unit & I assumed it would be bad, but now I'm not so sure.
Re: How do i test my fuel sending unit? [Re: Spanky] #1176242
02/11/12 12:20 AM
02/11/12 12:20 AM
W temp and gas gauges both not working that'd point to the voltage limiter, a small metal component on the back of the dash printed circuit going bad or an open & VL's are problematic & not likely that the wide copper printed circuit went open to both gauges from the VL. I'd prob drop the col a bit & pull the dash out enough to access its' backside & ohm it EDIT w a jumper wire connect the sender flat metal to the fuel line and blue hot wire plugged in have a helper see if the gauge needle swings toward F as you raise the float (key on). If it stays on the left side of E the prob ain't the sender but make sure you have it grounded for a valid test
Re: How do i test my fuel sending unit? [Re: Spanky] #1176243
02/11/12 12:33 AM
02/11/12 12:33 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
15 to 85 ohms on the fuel sending unit.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: How do i test my fuel sending unit? [Re: HemiRick] #1176244
02/11/12 01:02 AM
02/11/12 01:02 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If that voltage limiter goes bad it could fry all the gagues, i put a electronic one in mine.
Re: How do i test my fuel sending unit? [Re: Spanky] #1176245
02/11/12 01:50 AM
02/11/12 01:50 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
on my '69 B-body, it was the pins on the back of the printed circuit board...you know; the BIG round plug on the back of the cluster...wiggle it around a bit and see if the gauges start working. if so, it's resolder the pins or replace the board.
Re: How do i test my fuel sending unit? [Re: cornucopia] #1176246
02/11/12 10:56 AM
02/11/12 10:56 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Im fighting the same problem on my car right now both gauges do not work. Im going to get a voltage limiter today but here is a good article I found during my search.
http://www.moparfins.com/repairs/fuel_gauge_repair/fuel_gauge_repair.htm
Hope this helps
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: How do i test my fuel sending unit? [Re: Spanky] #1176247
02/13/12 02:31 PM
02/13/12 02:31 PM
dogdays Offline
dogdays  Offline
If you have soldering skills look up the solid state regulator conversion. Computers ued a 5VDC power supply and it is available on a chip.
It's much better than the original regulator that used dome sort of contacts that opened and closed to create an "average" 5 volts.
R.
