Re: How do i test my fuel sending unit?
[Re: Spanky]
#1176242
02/11/12 12:20 AM
02/11/12 12:20 AM
RapidRobert
W temp and gas gauges both not working that'd point to the voltage limiter, a small metal component on the back of the dash printed circuit going bad or an open & VL's are problematic & not likely that the wide copper printed circuit went open to both gauges from the VL. I'd prob drop the col a bit & pull the dash out enough to access its' backside & ohm it EDIT w a jumper wire connect the sender flat metal to the fuel line and blue hot wire plugged in have a helper see if the gauge needle swings toward F as you raise the float (key on). If it stays on the left side of E the prob ain't the sender but make sure you have it grounded for a valid test
[Re: Spanky]
#1176243
02/11/12 12:33 AM
02/11/12 12:33 AM
Posts: 4,848 Memphis
HemiRick
Memphis
15 to 85 ohms on the fuel sending unit.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
