Page 3 of 4 1 2 3 4
Re: All of my intake push rods are bent ..... Help [Re: 73rrak] #1173683
02/07/12 10:49 PM
02/07/12 10:49 PM
33950
67Monaco Offline
67Monaco  Offline
33950
That's how this whole project has gone so it was no real surprise to me. I'm telling you this car is possessed. 2 weeks ago I jacked up the front of the car to purge the air out of the motor. I was going to the back of the car to put gas in it getting ready to start it for the first time and it fell off the jack. It took out the billet aluminum crank pulley, Radiator, aluminum fan shroud, electric fan and the tranny cooler lines. I have never had a car even come close to falling off of a jack before this car. Just about everything on this car has had to be done twice. Things I've done dozens of times on other cars have to be done twice on this car. I was thinking of putting a cross in it but I'm afraid it will burn my house down ..... Hhahahhahhaha
You sure you wanna drive it if you ever get it done? I'd be concerned for personal safety..
Re: All of my intake push rods are bent ..... Help [Re: 73rrak] #1173684
02/07/12 10:51 PM
02/07/12 10:51 PM
Maine, USA
4spdswinger340 Offline
Maine, USA
If you took .010 off the heads and .030 off of the blocks deck and are running thin .020 gaskets, you would have needed shorter push rods or shim your rocker shafts to compensate the difference. Otherwise you would have to much preload. I wouldn't think it would be enough to bend push rods but it wouldn't help matters if you did not. Did you do so?
Life can be like fighting a dinosaur. Very hard
Re: All of my intake push rods are bent ..... Help [Re: 4spdswinger340] #1173685
02/07/12 11:01 PM
02/07/12 11:01 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If you took .010 off the heads and .030 off of the block you would have needed shorter push rods or shim your rocker shafts. Did you do so?
But he also said that he went back with a composite head gasket, vs the original shims, which adds most of that thickness right back in.
**Photobucket sucks**
Re: All of my intake push rods are bent ..... Help [Re: 4spdswinger340] #1173686
02/07/12 11:03 PM
02/07/12 11:03 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
It had the steel shim head gasket from the factory and I put a composite head gasket on so the should have taken up .020 of the .040 that was cut from the block at least that's what I thought. I hope I was wrong and the problem is just push rods too long.... and maybe a ruined cam.
When I take this car for it's first drive I think I'll bring a priest with me and drive it to my enemies house park it in his driveway then have the priest do an exorcism on the car so all the evil and demons go to my enemies cars ...... hahhahahahha
Re: All of my intake push rods are bent ..... Help [Re: 73rrak] #1173687
02/07/12 11:08 PM
02/07/12 11:08 PM
Maine, USA
Maine, USA
Had a buddy that bent a few pushrods in a 383 by milling the heads and installing a .509 cam @ the same time. He milled .070 off the heads and was running a .040 gasket. Only reason I mentioned it. His retainers were hitting the top of the valve seal. We changed the seals, bent push rods and then shimmed the rocker shafts and it is still running good 5 yrs later. Can you tell if the top of your seals are stove up?
Re: All of my intake push rods are bent ..... Help [Re: 73rrak] #1173688
02/07/12 11:09 PM
02/07/12 11:09 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Or maybe have your enemy take it for the first drive
Re: All of my intake push rods are bent ..... Help [Re: 73rrak] #1173689
02/07/12 11:25 PM
02/07/12 11:25 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
it's not your pushrods. I'd almost guarantee it.
if the pushrods were too long, then you'd have lifters bottomed out and hanging valves open.
who's valve springs are they? Hughes recommends their own springs/retainers to run with their cams, especially with the whiplash cams.
put a good pushrod into the valve train, and slowly crank the engine over by hand, again and again, let us know what you find. does it crank over smoohtly the whole way? do you feel anything binding up? can you visually inspect the valvespring/valves to ensure the coils are not binding up or the retainer hitting the valve guide?
I bought the whole Hughes setup.... Cam, lifters, springs and retainers. They told me that my springs would be fine because they only had 50,000 miles on them but I bought them anyway. I had them installed by a machine shop that has been doing work for me for years with no problems.
I think I will leave the camera in the cylinder and get the push rods checked and measured because it sounds like the heads are coming back off anyway.
Please try to leave everything assembled. Leave the camera in for now and fab the push rod checker. When that's done work on getting the camera out. Bring that cylinder up close enough to TDC by hand to get the camera out. It sounds like the engine turns over ok since the kid bumped the starter. Then we'll go from there...
Re: All of my intake push rods are bent ..... Help [Re: 4spdswinger340] #1173690
02/07/12 11:25 PM
02/07/12 11:25 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I can't really see the seals through the springs but from the little glimpse I can get they look normal but I can't say for sure until I get the locks, retainers and springs off.
Re: All of my intake push rods are bent ..... Help [Re: 73rrak] #1173691
02/08/12 12:53 AM
02/08/12 12:53 AM
moscow mills mo
smracing Offline
smracing  Offline
moscow mills mo
i would do a leak down test to check for bent valves before pulling the heads back off
Re: All of my intake push rods are bent ..... update ! [Re: 64Post] #1173692
02/08/12 11:16 PM
02/08/12 11:16 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Ok I got my push rod length checker made and these are the numbers I came up with :
Stock rod = 9.292
Rod checker results from lifter cup to rocker cup :
intake = 9.203
exhaust = 9.210
Is this enough to cause all of my intake push rods to bend. It doesn't look like a whole lot to me.
Re: All of my intake push rods are bent ..... Help [Re: smracing] #1173693
02/09/12 01:52 AM
02/09/12 01:52 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I put up a new thread because it looks like this one died.
Re: All of my intake push rods are bent ..... Help [Re: 73rrak] #1173694
02/09/12 07:55 AM
02/09/12 07:55 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Sorry about your mishaps with the car. What car is it?
And for the pushrods: Maybe they are just too weak for the type of springs and cam. I have seen 5/16" hollow pushrods bent like spaghetti on a 440 with obviously too hard springs (for those rods). I have bent pushrods myself due to sticky valveguides (because of old gummy fuel)
My
Re: All of my intake push rods are bent ..... Help [Re: Oyvind Mopar] #1173695
02/09/12 08:36 AM
02/09/12 08:36 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
The push rods are solid not hollow and the valves were cleaned and inspected when the new springs and locks were put on. The fuel system was clean and new fuel before fire up.
Re: All of my intake push rods are bent ..... update ! [Re: 73rrak] #1173696
02/09/12 10:43 AM
02/09/12 10:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Stock rod = 9.292
intake = 9.203
exhaust = 9.210
Did the stock length pushrod bottom out the lifter ? If the pushrod were to long and bottomed out the lifter I don't think it would have run fine for 20 minutes .
Re: All of my intake push rods are bent ..... Help [Re: 73rrak] #1173697
02/09/12 10:53 AM
02/09/12 10:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If I am reading this right all you did was change the springs and retainers ? if so your problem is the retainers probably hitting the tops of valve guides because that cam has a lot of lift , pull a spring and look at the stem seals , they should show evidence of being crushed between the retainer and the top of the guide .
Also a hollow pushrod is stronger than a solid one .
Re: All of my intake push rods are bent ..... Help [Re: JohnRR] #1173698
02/09/12 11:43 AM
02/09/12 11:43 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If I am reading this right all you did was change the springs and retainers ? if so your problem is the retainers probably hitting the tops of valve guides because that cam has a lot of lift , pull a spring and low at the stem seals , they should show evidence of being crushed between the retainer and the top of the guide .
John I think it ran for 20 minutes, then on the next re-start all the push rods bent. Remember he had a carb issue too. I think he wiped the cam then the push rods got hung up and bent.
73 Did you check the other bank? How do the ex push rods feel? Pull the dip stick and see how "sparkely" it is.
Re: All of my intake push rods are bent ..... Help [Re: Mr.Yuck] #1173699
02/09/12 11:51 AM
02/09/12 11:51 AM
bobs66440 Offline
bobs66440  Offline
Liquid fuel running down into the cylinders due to stuck floats can cause hydraulic lock and bend the the push rods if enough liquid was in the cylinders. I have also seen bent rods from this type of engine flooding also. that is why i never start a new motor with a used carb unless it was running the day before on my own stuff.
I have to say, if it ran ok for 20 minutes then bent the push rods on the next start up with nothing else changing other than a fuel issue, I would have to agree with this, unless it started running bad during the first start up but after the 20 minute break-in period. It's a little hard to tell, he has 3 threads going regarding this issue.
I would imagine if it hydro-locked it may have bent a rod or two also.
Re: All of my intake push rods are bent ..... Help [Re: bobs66440] #1173700
02/09/12 12:18 PM
02/09/12 12:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
gas isn't like water, if it sat over night the gas would be gone..he'd have to have a TON of gas flowing to do that wouldn't you think?
Re: All of my intake push rods are bent ..... Help [Re: Mr.Yuck] #1173701
02/09/12 12:39 PM
02/09/12 12:39 PM
bobs66440 Offline
bobs66440  Offline
I didn't know it sat overnight before the next start up. It's a little hard to follow the exact sequence of events.
Re: All of my intake push rods are bent ..... Help [Re: 73rrak] #1173702
02/09/12 12:41 PM
02/09/12 12:41 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I didn't get to take a picture before my neighbors 10 year old son grabbed the remote start and pushed the button chopping my camera of in the cylinder.
Quick, take off the remote start and hide it so even you can't find it.
I hate to make this sound like a broken record but you obviously have a clearance problem.
1. thats a lot of lift for stock length valve guides and stock pistons and not checking anything. Did you degree the cam? If it is advanced it will reduce Intake V-P clearance. The narrow lobe seperation angle will also reduce V-P clearance. http://www.compcams.com/technical/FAQ/LSAproperties.asp
2. a cam that big probably should not be using stock rockers, pushrods and springs no matter what Hughes may have told you.
3. since you have pistons with notches it might be difficult to see collision damage. If you are looking through the spark plug hole you are looking right at the wrong notches. The ones that might have damage will be facing away from plug hole.
I think you will be pulling the heads and maybe the pistons.
Page 3 of 4 1 2 3 4
