Bellhousing interchange #1170580
02/02/12 02:02 PM
02/02/12 02:02 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I have a bellhousing with a PN 2468370. Brewers lists it as a '65 B/C body bellhousing. Would this work for my '67 B body? If not what will be the issue.
Re: Bellhousing interchange [Re: GTX MATT] #1170581
02/02/12 02:21 PM
02/02/12 02:21 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Yes it will work, 130 tooth wheel and 4.35 bearing retainer hole. The only issue MAY be the attachment of the Z bar.
Re: Bellhousing interchange [Re: JohnRR] #1170582
02/02/12 04:29 PM
02/02/12 04:29 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Yep. Will work no problem. Ballstud will screw in lower of the 2 holes. You might have to change fork pivot depending on what it origanlly came out of. Dan
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Bellhousing interchange [Re: JohnRR] #1170583
02/04/12 03:38 AM
02/04/12 03:38 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Alright that is what I was worried about, where might I run into an issue? Is the bracket on the frame in the same location relative to the bell housing on '65 and '66/'67?
Re: Bellhousing interchange [Re: GTX MATT] #1170584
02/04/12 11:06 AM
02/04/12 11:06 AM
No idea on bracket location, but rapidfire above said it will work.
Re: Bellhousing interchange [Re: JohnRR] #1170585
02/05/12 03:32 AM
02/05/12 03:32 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Alright thanks guys
