Bellhousing interchange #1170580
02/02/12 02:02 PM
02/02/12 02:02 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I have a bellhousing with a PN 2468370. Brewers lists it as a '65 B/C body bellhousing. Would this work for my '67 B body? If not what will be the issue.
Re: Bellhousing interchange [Re: GTX MATT] #1170581
02/02/12 02:21 PM
02/02/12 02:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes it will work, 130 tooth wheel and 4.35 bearing retainer hole. The only issue MAY be the attachment of the Z bar.
Re: Bellhousing interchange [Re: JohnRR] #1170582
02/02/12 04:29 PM
02/02/12 04:29 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Yep. Will work no problem. Ballstud will screw in lower of the 2 holes. You might have to change fork pivot depending on what it origanlly came out of. Dan
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Bellhousing interchange [Re: JohnRR] #1170583
02/04/12 03:38 AM
02/04/12 03:38 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Alright that is what I was worried about, where might I run into an issue? Is the bracket on the frame in the same location relative to the bell housing on '65 and '66/'67?
Re: Bellhousing interchange [Re: GTX MATT] #1170584
02/04/12 11:06 AM
02/04/12 11:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No idea on bracket location, but rapidfire above said it will work.
Re: Bellhousing interchange [Re: JohnRR] #1170585
02/05/12 03:32 AM
02/05/12 03:32 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Alright thanks guys
