Meziere Reverse Flow Water Pump Users ? #1168551
01/30/12 02:22 PM
01/30/12 02:22 PM
Idabel,Oklahoma
Gary Robbins Offline OP
Idabel,Oklahoma
Does anybody using the big block pump have any pics they could share on how this thing looks plumbed...The 2 #12 an outlets that run back to where the upper hose goes looks like it could get funky...Any help would be appreciated...Gary
Re: Meziere Reverse Flow Water Pump Users ? [Re: Gary Robbins] #1168552
01/30/12 02:46 PM
01/30/12 02:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use one...
Not many good pictures but here is what I have. We made a t fitting for the upper lines.
Clearance with front mount distributor. Had to trim the cap a bit but has not been an issue. Could move it out a bit.
Re: Meziere Reverse Flow Water Pump Users ? [Re: Gary Robbins] #1168553
01/30/12 02:50 PM
01/30/12 02:50 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you mean like this?
Re: Meziere Reverse Flow Water Pump Users ? [Re: Al_Alguire] #1168554
01/30/12 02:57 PM
01/30/12 02:57 PM
Idabel,Oklahoma
Idabel,Oklahoma
Thanks Al...I was afraid thats what needed to be done and i don't have a radiator with AN fittings Back to the drawing board,a new radiator with AN fittings or install them on mine...
Re: Meziere Reverse Flow Water Pump Users ? [Re: rebel] #1168555
01/30/12 03:00 PM
01/30/12 03:00 PM
Idabel,Oklahoma
Idabel,Oklahoma
you mean like this?
Yep...May like your setup better...Thanks
Re: Meziere Reverse Flow Water Pump Users ? [Re: Gary Robbins] #1168556
01/30/12 03:02 PM
01/30/12 03:02 PM
Idabel,Oklahoma
Idabel,Oklahoma
Either of you guys running water back to center of head ?
Re: Meziere Reverse Flow Water Pump Users ? [Re: Gary Robbins] #1168557
01/30/12 03:05 PM
01/30/12 03:05 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
summit sells the weld on bungs and i had a local shop weld them on for 20$.i am going to use a remot pump tho.
Re: Meziere Reverse Flow Water Pump Users ? [Re: Gary Robbins] #1168558
01/30/12 03:07 PM
01/30/12 03:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Gary I do run water to the center of the heads as well in between the exhaust ports. You can see the lines one photo under the header. You do not have to use AN line just will need a tee it you only have one outlet as I do. I already had the fitting on the radiator from when the Hemi was in the car. You could simply make a tee with slip on hose.
Re: Meziere Reverse Flow Water Pump Users ? [Re: Gary Robbins] #1168559
01/30/12 11:49 PM
01/30/12 11:49 PM
AndyF Offline
AndyF  Offline
I used that water pump as my dyno setup for a few years. We used 1 inch heater hose rather than AN line. It should be easy to have two 1 inch hose inlets welded onto your radiator tank.
If you have a top down radiator then the hose routing is easy. If you have a cross flow radiator then the hoses have to both go over to one side of the car which isn't quite as clean. But either will work just fine.
Re: Meziere Reverse Flow Water Pump Users ? [Re: Gary Robbins] #1168560
01/31/12 12:57 AM
01/31/12 12:57 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i do. i found by drilling a 3/8 hole between the exhaust ports on the gasket made the pyro readings drop closer to the outboard pyro's.
Re: Meziere Reverse Flow Water Pump Users ? [Re: rebel] #1168561
01/31/12 01:48 AM
01/31/12 01:48 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
I have been switching back and forth on the reverse flow cooling bandwagon. IMO the only thing you get with a reverse flow is trapped air and no power gains . I can switch mine setup in 5 minutes . ( I used to run a Holley red fuel pump for my cooling system but have switched to solid
heads now )
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Meziere Reverse Flow Water Pump Users ? [Re: go green] #1168562
02/02/12 11:20 PM
02/02/12 11:20 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I use the Indy / Mezziere setup and it works great . Overheating is not an issue.
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
