Re: Meziere Reverse Flow Water Pump Users ?
[Re: rebel]
#1168555
01/30/12 03:00 PM
01/30/12 03:00 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
you mean like this?
Yep...May like your setup better...Thanks
[Re: Gary Robbins]
#1168557
01/30/12 03:05 PM
01/30/12 03:05 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
summit sells the weld on bungs and i had a local shop weld them on for 20$.i am going to use a remot pump tho.
[Re: Gary Robbins]
#1168558
01/30/12 03:07 PM
01/30/12 03:07 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Gary I do run water to the center of the heads as well in between the exhaust ports. You can see the lines one photo under the header. You do not have to use AN line just will need a tee it you only have one outlet as I do. I already had the fitting on the radiator from when the Hemi was in the car. You could simply make a tee with slip on hose.
[Re: Gary Robbins]
#1168560
01/31/12 12:57 AM
01/31/12 12:57 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Either of you guys running water back to center of head ?
i do. i found by drilling a 3/8 hole between the exhaust ports on the gasket made the pyro readings drop closer to the outboard pyro's.
