Weird Cam Bolt Washer #1168476
01/30/12 11:37 AM
01/30/12 11:37 AM
Out in Left Field, NY
bobs66440 Offline OP
I've never seen a washer like this. Is it a lock washer of some sort? It was on the engine when I got it.
Re: Weird Cam Bolt Washer [Re: bobs66440] #1168477
01/30/12 11:38 AM
01/30/12 11:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
WRONG washer , thats there because someone LOST the correct one , get it changed out .
Re: Weird Cam Bolt Washer [Re: JohnRR] #1168478
01/30/12 11:44 AM
01/30/12 11:44 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I would not use that washer look at how the bolt head is cutting into the soft washer. Is that a dome washer ??
logan426
Re: Weird Cam Bolt Washer [Re: MLR426] #1168479
01/30/12 12:46 PM
01/30/12 12:46 PM
Ok, I thought it looked wrong. Can I use a standard flat washer? I looked on 440 Source and theirs just looks like a thick flat washer.
Re: Weird Cam Bolt Washer [Re: bobs66440] #1168480
01/30/12 12:54 PM
01/30/12 12:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NO you need the correct washer , it's THICK for a reason .
Re: Weird Cam Bolt Washer [Re: JohnRR] #1168481
01/30/12 01:13 PM
01/30/12 01:13 PM
Right, I meant can I use a thick flat washer like from a hardware store. I looked on Summit site and they only show the bolt. I have to place an order with them anyway so I'll ask if they have any in stock. Thanks.
Re: Weird Cam Bolt Washer [Re: bobs66440] #1168482
01/30/12 01:14 PM
01/30/12 01:14 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
looks like they used a cupped shock absorber washer?
Smallblock has to use a cupped washer, but I'm bot sure about the bigblock? It might be a thick flat washer. I might have a few laying around, I went to the 3-bolt cam/timing sets on all my bigblocks.
Re: Weird Cam Bolt Washer [Re: 451Mopar] #1168483
01/30/12 01:30 PM
01/30/12 01:30 PM
I called Summit and they don't have anything like that. I need a thick 7/16 flat washer with a 1-1/4" outside diameter to stay inside the pin coming through the cam sprocket. This is a Cloyes timing set. I'm not sure if they are all like this.
I'll have to call 440 Source when they open.
Re: Weird Cam Bolt Washer [Re: bobs66440] #1168484
01/30/12 01:47 PM
01/30/12 01:47 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
http://chucker54.stores.yahoo.net/camathar1.html
$9 at Mancini...bolt and washer..
Re: Weird Cam Bolt Washer [Re: bobs66440] #1168485
01/30/12 02:09 PM
01/30/12 02:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't thing you are not going to get the correct thick HARDENED washer at the hardware store.
I want to say the right washer should overlap the head of that pin some ? I don't remember ???
Re: Weird Cam Bolt Washer [Re: JohnRR] #1168486
01/30/12 02:48 PM
01/30/12 02:48 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
Re: Weird Cam Bolt Washer [Re: ditchdrift] #1168487
01/30/12 09:20 PM
01/30/12 09:20 PM
Re: Weird Cam Bolt Washer [Re: bobs66440] #1168488
01/31/12 06:09 PM
01/31/12 06:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The original single-bolt cam washer is a Belleville washer (slightly cup-shaped)...if the replacement isn't a Belleville I would be sure to use red Loctite on the bolt.
Re: Weird Cam Bolt Washer [Re: John_Kunkel] #1168489
01/31/12 06:25 PM
01/31/12 06:25 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Yes I agree with the cupped version but that cupped washer looks dead soft.
logan426
Re: Weird Cam Bolt Washer [Re: bobs66440] #1168490
01/31/12 07:05 PM
01/31/12 07:05 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
it looks like somebody lost the correct washer and used some kind of shock washer as a replacement.
Re: Weird Cam Bolt Washer [Re: 446acuda] #1168491
01/31/12 08:11 PM
01/31/12 08:11 PM
That's what it is! I compared it to a shock washer (or maybe sway bar bushing washer) I had in the parts bin and it's identical.
Re: Weird Cam Bolt Washer [Re: bobs66440] #1168492
02/01/12 12:39 PM
02/01/12 12:39 PM
scratchnfotraction Offline
makes one wonder what else trick was used in that build?
Re: Weird Cam Bolt Washer [Re: scratchnfotraction] #1168493
02/01/12 01:03 PM
02/01/12 01:03 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Fram oil filter?
Re: Weird Cam Bolt Washer [Re: scratchnfotraction] #1168494
02/01/12 01:15 PM
02/01/12 01:15 PM
New State
kidmopar Offline
kidmopar  Offline
New State
Looks like a drilled-out shock absorber washer? I'd sure look a LOT deeper into that one
Re: Weird Cam Bolt Washer [Re: mopars4ever] #1168495
02/01/12 01:26 PM
02/01/12 01:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And !!
