500 ci cam recomendations #1164516
01/25/12 12:31 PM
01/25/12 12:31 PM
wyo
70 vcodecuda Offline OP
wyo
here's the build
500ci
cnc stealth heads
10.5 comp
stock six pack setup
1 7/8 tti feaders
2.5 or 3' exhaust?
hyd or roller?
4 speed car
3.54 gears
1970 Cuda V code 4speed Shaker 2009 Challenger RT 2003 Ram 2500 Quad Cab CTD
Re: 500 ci cam recomendations [Re: 70 vcodecuda] #1164517
01/25/12 01:29 PM
01/25/12 01:29 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
here's the build
500ci
hyd or roller?
What is your budget? I guess you know that there are 4 types of commonly available cams? Solid flat, Solid roller, Hydraulic flat and Hydraulic roller..... I was ready to run a hydraulic roller until I checked priced... W O W !!! Its around $1000 for the cam, special lifters, the pushrods, the bronze distributor drive.... Too much for me. I went flat tappet and use better oil.
My 493 currently has the old dinosaur Mopar performance 292/509 hydraylic. It runs okay but I liked the Comp XE 285HL better. I wiped out 2 Comp Cams and decided to skip using them until they improved their manufacturing. It seems that they got the message, since they now offer an improved surface hardening option. I may go back. That Comp cam idled better and made more power.
Re: 500 ci cam recomendations [Re: 70 vcodecuda] #1164518
01/25/12 02:24 PM
01/25/12 02:24 PM
wyo
wyo
yea i know the difference in cams
right now it's a 440 with 906's stock exhaust manifolds
10.5 comp
looks as thou it has squashed a piston so looking to stealth heads
it also has comp xe295hl and maybe this will be good for the new build ?
Re: 500 ci cam recomendations [Re: 70 vcodecuda] #1164519
01/25/12 02:24 PM
01/25/12 02:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my engine came w/ a comp cams 588 solid roller, runs killer. However as mentioned it's not a cheap set-up. Are you going w/ roller rockers? Do you want to adjust the lash from time to time? What is the application? I'd think something in the 540-560 lift range would work well for you. Try one of the custom cam guys. They can grind you up a cam for around $200.
Coming soon!!!!
Re: 500 ci cam recomendations [Re: 70 vcodecuda] #1164520
01/25/12 03:07 PM
01/25/12 03:07 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
here's the build
500ci
cnc stealth heads
10.5 comp
1 7/8 tti feaders
2.5 or 3' exhaust?
hyd or roller?
4 speed car
3.54 gears
Along my research through the years I have collected the parts. Mine is a 505. Although my setup has Eddy's, Dual Quads, Hedman Shorties, and 727 w/ GVO. We only match the same compression. I went ahead and bit the bullet on the roller setup. Talked with a few guys and at the time I was doing cam selection, they were using less nickel in their casting at ALL the foundries. This was about 3-4 yrs ago. The guy who owned the speed shop I always bought parts from told me he wont sell me anything cam wise unless it was a roller, otherwise I should go back in 6 months and see it it had changed. . I bought the XR-280, went ahead and bought the roller lifters. The only thing I dont have are the pushrods because I am far from assembly. I decided to buy myself a present last Christmas and I have the Harland's on a boat thats docking next week.
I can't verify the cam, but my setup uses the one above...541/.537 ...Eventually I'll have to swap out the springs on the Eddy heads but no rush, do the springs on the Stealth's hold up?...The only thing I fear won't hold up against the torque would be the trans.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 500 ci cam recomendations [Re: Pyper70] #1164521
01/25/12 03:19 PM
01/25/12 03:19 PM
wyo
wyo
this will be for my cuda to drive,show,and a little track time
really like the stealth to keep it stock looking ( except for the headers)so i have to keep the six pack really been looking at the rollers (cost does play into that decision)all ready have comp rollers rockers also live at high elevation (7000 feet) so we generally need to build big to get what you sea level guy's have.
also wondering if the six pack works well with cnc stealth's and 500 ci ?
Re: 500 ci cam recomendations [Re: 70 vcodecuda] #1164522
01/25/12 03:35 PM
01/25/12 03:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd probably port match and clean up the intake. I'd also add some jetting and squirtters to the six pack before you put it on. Once those hard metal lines are in place it's a PITB to get anything done. I went w/ 70 jets, 4.5PV, 35 squirtters and purple outboards.
Coming soon!!!!
Re: 500 ci cam recomendations [Re: 70 vcodecuda] #1164523
01/25/12 04:06 PM
01/25/12 04:06 PM
I used the XE295HL in my 464 C.I. six pak motor, 440 block, 4.35 bore with 3.91 stroke, Eddy RPM heads,Harland Sharp 1.5 roller rockers, Eddy stock aluminum replacement six pak intake , vacume six pak Holley carbs, 10.4 to 1 compression. It ran good in the car, no way that cam can be mistaken or misrepresented as a stock 440 magnum cam If the cam is in good shape use it in the new motor, strokers motors eat up duration
Re: 500 ci cam recomendations [Re: 70 vcodecuda] #1164524
01/26/12 04:33 AM
01/26/12 04:33 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
here's the build
500ci
cnc stealth heads
10.5 comp
1 7/8 tti feaders
2.5 or 3' exhaust?
hyd or roller?
4 speed car
3.54 gears
Thats pretty close to my 505 combination.
505" 440, Stealth heads with some port cleanup and multi-angle valve job (289 cfm), 10.3:1 compression, Edelbrock RPM intake and 770 Holley (for now. want FI in the future.)
1-7/8" TTI headers, 2.5" TTI X-pipe exhaust, (if they fit) Walker Quiet flow mufflers.
Comp XR286HR-10 Hydraulic Roller cam, 236/242 @ 0.050", 0.617"/0.614" lift with 1.7:1 rockers (CAT stainless steel rockers. I have not verified the true ratio so lift may be a bit less?)
ISKY 8005A springs, Hughes Hydraulic lifters, Comp 478-16 10-degree retainers and the Comp 611-16 10-degree locks. Smith Brothers 5/16" dia. x 0.083" wall x 8.475" long ball/ball pushrods.
4-speed, 4.10:1 dana60, but looking to go 5-speed trans..
I wanted to build this on the mild side, just something nice to drive, not race.
It's almost done!
Re: 500 ci cam recomendations [Re: 451Mopar] #1164525
01/26/12 04:36 AM
01/26/12 04:36 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the '69 440 was supposed to be teal, but I like the Hemi orange better
Re: 500 ci cam recomendations [Re: 451Mopar] #1164526
01/26/12 11:52 AM
01/26/12 11:52 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Generally 68 Big blocks were Teal, 69-71 Magnums were orange (non mags were still teal) but I'm sure there were some early build 69's that had Teal colored motors.
WIZE
In Car:
Re: 500 ci cam recomendations [Re: Streetwize] #1164527
01/26/12 12:37 PM
01/26/12 12:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
All BB should be orange, no matter the year. Especailly in 68-up cars.
Coming soon!!!!
Re: 500 ci cam recomendations [Re: Mr.Yuck] #1164528
01/26/12 02:06 PM
01/26/12 02:06 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
my original 69 block was Teal....and the 67 440 I picked up was also Teal...
Re: 500 ci cam recomendations [Re: Pyper70] #1164529
01/26/12 02:37 PM
01/26/12 02:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
69 magnum engines (including 383's) should be orange.
Re: 500 ci cam recomendations [Re: Pyper70] #1164530
01/26/12 02:37 PM
01/26/12 02:37 PM
MO, USA
The Dodge Guy Offline
MO, USA
My 65 426 wedge is teal..... Just saying.
Re: 500 ci cam recomendations [Re: The Dodge Guy] #1164531
01/26/12 02:47 PM
01/26/12 02:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes teal was the color until 69 I believe.
Coming soon!!!!
Re: 500 ci cam recomendations [Re: 451Mopar] #1164532
01/26/12 03:52 PM
01/26/12 03:52 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
It's almost done!
WOW that looks great, thats exactly what I am working on right now too, haven't picked the cam though yet. Question how well did the 1.7 cats fit under the stock valve covers? Did you have to do anything to get them to fit? I am also interested in the cam select quetion here.
Re: 500 ci cam recomendations [Re: Cab_Burge] #1164533
01/26/12 04:10 PM
01/26/12 04:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I had that cam in my old 440 and it works very well with a stick car.
My new 493 has a Comp flat solid grind XTQ 294 S It's a pretty mild solid cam with tons of mid range
intake 567/264@ 50 exhaust 579/270@ 50
Gus
64 Plymouth Savoy
Dana 60
