500 ci cam recomendations
#1164516
01/25/12 12:31 PM
01/25/12 12:31 PM
Posts: 67 wyo
70 vcodecuda
wyo
here's the build 500ci cnc stealth heads 10.5 comp stock six pack setup 1 7/8 tti feaders 2.5 or 3' exhaust? hyd or roller? 4 speed car 3.54 gears
1970 Cuda V code 4speed Shaker
2009 Challenger RT
2003 Ram 2500 Quad Cab CTD
Re: 500 ci cam recomendations
[Re: 70 vcodecuda]
#1164517
01/25/12 01:29 PM
01/25/12 01:29 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
hyd or roller?
What is your budget? I guess you know that there are 4 types of commonly available cams? Solid flat, Solid roller, Hydraulic flat and Hydraulic roller..... I was ready to run a hydraulic roller until I checked priced... W O W !!! Its around $1000 for the cam, special lifters, the pushrods, the bronze distributor drive.... Too much for me. I went flat tappet and use better oil. My 493 currently has the old dinosaur Mopar performance 292/509 hydraylic. It runs okay but I liked the Comp XE 285HL better. I wiped out 2 Comp Cams and decided to skip using them until they improved their manufacturing. It seems that they got the message, since they now offer an improved surface hardening option. I may go back. That Comp cam idled better and made more power.
[Re: 70 vcodecuda]
#1164518
01/25/12 02:24 PM
01/25/12 02:24 PM
Posts: 67 wyo
70 vcodecuda
wyo
yea i know the difference in cams right now it's a 440 with 906's stock exhaust manifolds 10.5 comp looks as thou it has squashed a piston so looking to stealth heads it also has comp xe295hl and maybe this will be good for the new build ?
2009 Challenger RT
[Re: 70 vcodecuda]
#1164520
01/25/12 03:07 PM
01/25/12 03:07 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
Along my research through the years I have collected the parts. Mine is a 505. Although my setup has Eddy's, Dual Quads, Hedman Shorties, and 727 w/ GVO. We only match the same compression. I went ahead and bit the bullet on the roller setup. Talked with a few guys and at the time I was doing cam selection, they were using less nickel in their casting at ALL the foundries. This was about 3-4 yrs ago. The guy who owned the speed shop I always bought parts from told me he wont sell me anything cam wise unless it was a roller, otherwise I should go back in 6 months and see it it had changed. . I bought the XR-280, went ahead and bought the roller lifters. The only thing I dont have are the pushrods because I am far from assembly. I decided to buy myself a present last Christmas and I have the Harland's on a boat thats docking next week.
I can't verify the cam, but my setup uses the one above...541/.537 ...Eventually I'll have to swap out the springs on the Eddy heads but no rush, do the springs on the Stealth's hold up?...The only thing I fear won't hold up against the torque would be the trans.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1164521
01/25/12 03:19 PM
01/25/12 03:19 PM
Posts: 67 wyo
70 vcodecuda
wyo
this will be for my cuda to drive,show,and a little track time really like the stealth to keep it stock looking ( except for the headers)so i have to keep the six pack really been looking at the rollers (cost does play into that decision)all ready have comp rollers rockers also live at high elevation (7000 feet) so we generally need to build big to get what you sea level guy's have. also wondering if the six pack works well with cnc stealth's and 500 ci ?
2009 Challenger RT
[Re: 70 vcodecuda]
#1164523
01/25/12 04:06 PM
01/25/12 04:06 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I used the XE295HL in my 464 C.I. six pak motor, 440 block, 4.35 bore with 3.91 stroke, Eddy RPM heads,Harland Sharp 1.5 roller rockers, Eddy stock aluminum replacement six pak intake , vacume six pak Holley carbs, 10.4 to 1 compression. It ran good in the car, no way that cam can be mistaken or misrepresented as a stock 440 magnum cam If the cam is in good shape use it in the new motor, strokers motors eat up duration
[Re: 70 vcodecuda]
#1164524
01/26/12 04:33 AM
01/26/12 04:33 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Thats pretty close to my 505 combination. 505" 440, Stealth heads with some port cleanup and multi-angle valve job (289 cfm), 10.3:1 compression, Edelbrock RPM intake and 770 Holley (for now. want FI in the future.) 1-7/8" TTI headers, 2.5" TTI X-pipe exhaust, (if they fit) Walker Quiet flow mufflers. Comp XR286HR-10 Hydraulic Roller cam, 236/242 @ 0.050", 0.617"/0.614" lift with 1.7:1 rockers (CAT stainless steel rockers. I have not verified the true ratio so lift may be a bit less?) ISKY 8005A springs, Hughes Hydraulic lifters, Comp 478-16 10-degree retainers and the Comp 611-16 10-degree locks. Smith Brothers 5/16" dia. x 0.083" wall x 8.475" long ball/ball pushrods. 4-speed, 4.10:1 dana60, but looking to go 5-speed trans..
I wanted to build this on the mild side, just something nice to drive, not race. It's almost done!
[Re: 451Mopar]
#1164526
01/26/12 11:52 AM
01/26/12 11:52 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Generally 68 Big blocks were Teal, 69-71 Magnums were orange (non mags were still teal) but I'm sure there were some early build 69's that had Teal colored motors.
[Re: Mr.Yuck]
#1164528
01/26/12 02:06 PM
01/26/12 02:06 PM
Pyper70
Athens, Greece
my original 69 block was Teal....and the 67 440 I picked up was also Teal...
[Re: Cab_Burge]
#1164533
01/26/12 04:10 PM
01/26/12 04:10 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I had that cam in my old 440 and it works very well with a stick car. My new 493 has a Comp flat solid grind XTQ 294 S It's a pretty mild solid cam with tons of mid range intake 567/264@ 50 exhaust 579/270@ 50 Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
