gas cable different 4 bbl and 2 bbl on 74 duster? #116272
09/06/08 11:04 PM
09/06/08 11:04 PM
quebec,Canada
swinger72 Offline OP
quebec,Canada
i am putting a 2 bbl carb on my duster with original intake i remouved the 4 bbl carb and edelbroock intake the cable is too long is there a difference between 2 aND 4 BBL?if so i will have to find one for a 2 bbl carb thanks Mike
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: swinger72] #116273
09/07/08 09:36 AM
09/07/08 09:36 AM
quebec,Canada
quebec,Canada
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: swinger72] #116274
09/07/08 12:19 PM
09/07/08 12:19 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
They are definitely different...kick down linkage as well. The better question is why remove the 4bbl carb? Less power, less fuel economy than a properly tuned 4bbl when you have a 2bbl
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: goldduster318] #116275
09/07/08 12:54 PM
09/07/08 12:54 PM
PA
70Duster Offline
70Duster  Offline
PA
Throttle cable is the same. Only the linkage and mounting bracket are different.
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: goldduster318] #116276
09/07/08 06:14 PM
09/07/08 06:14 PM
quebec,Canada
quebec,Canada
the reason is i am putting the 4BBl on my car it is a edelbroock performer wioth a 650 cfm and the 2bbl on the car that i am selling the kickdown linkage seems the same but the gas cable seems longer , one of you says its the same the other they are different you got me wondering
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: swinger72] #116277
09/08/08 10:00 AM
09/08/08 10:00 AM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Like said the Cable length is fine for either....the Bracket that holds the cable( the one that bolts to the intake ) is different from 2 bbl to 4 bbl as well as the KD rod .
The part of the bracket that clamps around the throttle cable is further towards the firewall on a 2 bbl than a 4 bbl.
Just stuck an Eddy & 600 Holley on a 318 that had a 2 bbl & all I did was pull the correct 4 bbl Bracket outta stock & use it with the old 2bbl cable. Had to tweak the KD rod since I didn't have any 4bbl ones left.
Butch
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: CHRYCOFAN] #116278
09/08/08 10:12 AM
09/08/08 10:12 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
2bbl and 4bbl cables are different. Have different travel lengths. Different part#. So are the cable brackets.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: moparmarks] #116279
09/08/08 12:19 PM
09/08/08 12:19 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
So there are 2 cables...good to know.
The 2 bbl cable did at least have enough length to work in my conversion without having to have an extension.
Sounds like in his case he might just want to swap to keep the longer cable for future use.
Butch
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: CHRYCOFAN] #116280
09/08/08 01:26 PM
09/08/08 01:26 PM
quebec,Canada
quebec,Canada
thanks for info i ll check out the brackets and cable side by side to be sure one car in driveway the other in garage a few miles away so comparing was not easy , take both oiff and will see
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: swinger72] #116281
09/08/08 07:46 PM
09/08/08 07:46 PM
quebec,Canada
quebec,Canada
sure enough , i took the bracket off the 2 bbl and looking at both side by side the 2 bbl is like said closer to firewall this will help as my cable was to long to travel the complete swing of pedal now with the bracket being furter back i get my full travel thanks guys Mike
Re: gas cable different 4 bbl and 2 bbl on 74 duster? [Re: swinger72] #116282
09/08/08 08:09 PM
09/08/08 08:09 PM
moparmarks Offline
moparmarks  Offline
Heres the brackets. I forgot your going from a 4bbl to a 2bbl. The 4bbl cable may work. If you use a 2bbl cable on a 4bbl, not enough travel to open the 4bbl all the way open.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: gas cable different 4 bbl and 2 bbl on 74 dust [Re: moparmarks] #116283
09/09/08 06:30 PM
09/09/08 06:30 PM
5thAve Offline
5thAve  Offline
A 2 barrel cable works with a 4 barrel too as long as you have the right bracket.
Re: gas cable different 4 bbl and 2 bbl on 74 dust [Re: 5thAve] #116284
09/09/08 07:57 PM
09/09/08 07:57 PM
quebec,Canada
quebec,Canada
thanks everyone got it hooked up and running on the 2 bbl next install the intake and 4 bbl on my car should go ok
