Re: gas cable different 4 bbl and 2 bbl on 74 duster?
[Re: swinger72]
#116274
09/07/08 12:19 PM
09/07/08 12:19 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
They are definitely different...kick down linkage as well. The better question is why remove the 4bbl carb? Less power, less fuel economy than a properly tuned 4bbl when you have a 2bbl
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: swinger72]
#116282
09/08/08 08:09 PM
09/08/08 08:09 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
sure enough , i took the bracket off the 2 bbl and looking at both side by side the 2 bbl is like said closer to firewall this will help as my cable was to long to travel the complete swing of pedal now with the bracket being furter back i get my full travel thanks guys Mike
Heres the brackets. I forgot your going from a 4bbl to a 2bbl. The 4bbl cable may work. If you use a 2bbl cable on a 4bbl, not enough travel to open the 4bbl all the way open.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
