MSD coil blaster 2 8202 #1162734
01/22/12 05:36 PM
01/22/12 05:36 PM
Canada
Dons Dart Offline OP
Canada
I have this coil can it be laid on its side,I like the stock look on my intake,but have read were it says do not lay on its side and read were it says can be installed in any position ideas.
Re: MSD coil blaster 2 8202 [Re: Dons Dart] #1162735
01/22/12 05:59 PM
01/22/12 05:59 PM
On my bigblock I mounted it in the coil bracket but mounted the coil bracket to the inner fender with the coil vertical.
On my smallblock I used to mount them on the firewall.
Re: MSD coil blaster 2 8202 #1162736
01/22/12 06:37 PM
01/22/12 06:37 PM
Canada
Canada
Still does not answer my Question.
Re: MSD coil blaster 2 8202 [Re: Dons Dart] #1162737
01/22/12 06:44 PM
01/22/12 06:44 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Its pretty simple. Google msd and get the answer from the horses mouth.
Part number: 8202
If you are looking to upgrade your stock coil, or want to compliment the performance of your MSD Blaster Ignition, MSD 5, 6 or 7, the Blaster Coil lin (...)
Make sure to mount these coils vertically, since they do contain oil in them to cool the windings.
Re: MSD coil blaster 2 8202 [Re: NITROUSN] #1162738
01/22/12 06:52 PM
01/22/12 06:52 PM
Canada
Canada
Ok got my answer I Google it and came right to here were there was a lot of thoughts on how to install it so up right it will be thanks Moparts.
Re: MSD coil blaster 2 8202 [Re: Dons Dart] #1162739
01/22/12 10:24 PM
01/22/12 10:24 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
as a second option you can get Napa coil and use it in the original bracket, you wont feel any difference between the two.
Re: MSD coil blaster 2 8202 [Re: Dons Dart] #1162740
01/23/12 10:55 AM
01/23/12 10:55 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
ive always mounted mine in the (on the) manifold and had no problems ,i know msd says to mount it in a verticle position.
Re: MSD coil blaster 2 8202 [Re: moparsquid] #1162741
01/23/12 11:16 AM
01/23/12 11:16 AM
OT, Andy makes a nice bracket to mount em vertical at the front valley holdown plate
Re: MSD coil blaster 2 8202 [Re: RapidRobert] #1162742
01/23/12 12:55 PM
01/23/12 12:55 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The one on my Street Hemi has been mounted in the original horizontal position since 1987, no problems.
Re: MSD coil blaster 2 8202 [Re: Dons Dart] #1162743
01/23/12 02:46 PM
01/23/12 02:46 PM
AndyF Offline
AndyF  Offline
