Re: without busting the drum ...how to unstick them?
[Re: bboogieart]
#1160860
01/19/12 09:33 PM
01/19/12 09:33 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Cant rotate it guiess the movement im getting is from colapse the short springs that hold shoes to back plate
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: Challenger 1]
#1160862
01/20/12 08:19 AM
01/20/12 08:19 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Typically there is a ridge in the drum.Its about 1/4 inch.Thats where the drum dosent contact the shoes.They can be a bear to get off.You can grind the pin heads off in the backing plate and they usually come off.Ive had to pry some off.Use a few heavy screwdrivers and work them off.When I replace drums I usually cut the outer edge down a bit on the brake lathe.That way the ridge dosent catch like without the slight cut.Same thing when I turn drums.I cut that outer edge about .100 deeper than the drum is turned.Rocky
Chrysler Firepower
[Re: therocks]
#1160863
01/20/12 08:34 AM
01/20/12 08:34 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
I just went through this very thing on a rear drum on a '71 Mustang. What I did there, and have done before, is take a cold chisel and cut the heads off the "nails" for the shoe hold-down springs (look at the diagram posted earlier). That releases the shoes to pivot on the upper anchor. Worked for me every time.
[Re: dogdays]
#1160865
01/20/12 04:27 PM
01/20/12 04:27 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Il give it a try next decent day im off got a ? Thou... On the back the car has a sure grip ....going foward neither tire will roll but going backward the passenger tire will/did turn/roll backward is this cause of the sure grip not letting it turn from other hub stuck or is it just something in that drum only letting it turn one way?
[Re: radar]
#1160867
01/20/12 07:39 PM
01/20/12 07:39 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
BFH
No ...a LITTLER one ...
I have uNstuck a couple of these in a Dana 70 in the past couple of years. A short-handled 4? lb sledge has wurked-ferr-me.
[Re: Pyper70]
#1160870
01/23/12 09:58 AM
01/23/12 09:58 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
The flame torch is a good idea too. You may have a raised rust ring on the center hub and that may be keeping it form coming off too.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
