Re: without busting the drum ...how to unstick them? [Re: bboogieart] #1160860
01/19/12 09:33 PM
01/19/12 09:33 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Cant rotate it guiess the movement im getting is from colapse the short springs that hold shoes to back plate
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: without busting the drum ...how to unstick them? [Re: toplescuda] #1160861
01/20/12 01:24 AM
01/20/12 01:24 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
BFH
Re: without busting the drum ...how to unstick them? [Re: Challenger 1] #1160862
01/20/12 08:19 AM
01/20/12 08:19 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Typically there is a ridge in the drum.Its about 1/4 inch.Thats where the drum dosent contact the shoes.They can be a bear to get off.You can grind the pin heads off in the backing plate and they usually come off.Ive had to pry some off.Use a few heavy screwdrivers and work them off.When I replace drums I usually cut the outer edge down a bit on the brake lathe.That way the ridge dosent catch like without the slight cut.Same thing when I turn drums.I cut that outer edge about .100 deeper than the drum is turned.Rocky
Chrysler Firepower
Re: without busting the drum ...how to unstick them? [Re: therocks] #1160863
01/20/12 08:34 AM
01/20/12 08:34 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I just went through this very thing on a rear drum on a '71 Mustang. What I did there, and have done before, is take a cold chisel and cut the heads off the "nails" for the shoe hold-down springs (look at the diagram posted earlier). That releases the shoes to pivot on the upper anchor. Worked for me every time.
Re: without busting the drum ...how to unstick them? [Re: 6PakBee] #1160864
01/20/12 11:57 AM
01/20/12 11:57 AM
dogdays Offline
dogdays  Offline
This is the sensible answer, suggested by several. You cut the heads of the nail-like pins and pull the drum as hard as you can. You may ruin the springs at the anchor pin attachment, but they can be replaced easily. I believe on my last one I used a two foot pry bar. Once the drum and whatever is stuck to it is off the car it's an easy job to get everything loose.
One warning: If you take the drums to a shop make sure that they take off a minimal cut. I've noticed many shops will set the cutter to either the maximum ID of a drum or the minimum thickness of the disk. No brains involved, plus next time they get to sell you a new drum or disk.
If you are sticking with drums I'd suggest Praise Dyno Brake as a source of better-than-stock brake shoes.
R.
Re: without busting the drum ...how to unstick them? [Re: dogdays] #1160865
01/20/12 04:27 PM
01/20/12 04:27 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Il give it a try next decent day im off
got a ? Thou... On the back the car has a sure grip ....going foward neither tire will roll but going backward the passenger tire will/did turn/roll backward is this cause of the sure grip not letting it turn from other hub stuck or is it just something in that drum only letting it turn one way?
1971 charger
Re: without busting the drum ...how to unstick them? [Re: toplescuda] #1160866
01/20/12 07:34 PM
01/20/12 07:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You'll find that answer when you get the drums off.
Re: without busting the drum ...how to unstick them? [Re: radar] #1160867
01/20/12 07:39 PM
01/20/12 07:39 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
BFH
No ...a LITTLER one ...
I have uNstuck a couple of these in a Dana 70 in the past couple of years. A short-handled 4? lb sledge has wurked-ferr-me.
Re: without busting the drum ...how to unstick them? [Re: Challenger 1] #1160868
01/21/12 07:27 AM
01/21/12 07:27 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
Those things can be tough to get off sometimes. They do make a drum puller which helps a lot.
Big sledge hammer has been used before by me to break them into peices.
I think you should convert to disc brakes up front because front drums are gonna be hard to find I think. I converted my 71 from 4 wheel drum brakes, used spindles from a 73 E body that I used to own.
I do still have the old 11" drums from the front but have never took them apart yet to check them out.
What's crazy is my best new parts guy who I have known for a long time called me recently looking for those front 11" drums for one of his customers, he tells me he can't get them anymore?
i would convert to disc brakes also.keep the drums if you ever need them.there is no reason in the world not to have disc brakes,expecially on such a nice car.i would want all the modern stopping advantage i could get.
Re: without busting the drum ...how to unstick them? [Re: mcmopars] #1160869
01/21/12 07:37 AM
01/21/12 07:37 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Liquid Wrench, a crowbar, a sledge hammer and a little
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: without busting the drum ...how to unstick them? [Re: Pyper70] #1160870
01/23/12 09:58 AM
01/23/12 09:58 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
The flame torch is a good idea too. You may have a raised rust ring on the center hub and that may be keeping it form coming off too.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
