without busting the drum ...how to unstick them?
#1160840
01/19/12 06:37 PM
01/19/12 06:37 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I have 3 drums stuck 1 front 2 rear but one possible cause of suregrip?? Cause will turn backwards the front driver side i took wheel off and pryed the hub all around and it moves ok except the very top have pulled it on the paved driveway it just slides took the spindel nut off and can get the bottom to come out bout 1 inch or so but very top wont buldge
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: without busting the drum ...how to unstick them?
[Re: mod5v]
#1160842
01/19/12 07:17 PM
01/19/12 07:17 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
and if they're rusted to the flange...a little break free like PB blaster, WD40, etc. and a little heat can help. maybe a slide hammer too if you have the jaws to grab the backside of the drum. but back off the brake shoes first. they wear into the drum leaving a lip on the outside of it, which is why we turn the drums on brake jobs. as the self adjusters click "out" the shoe expands into the lip. gotta get the shoes backed off all the way to allow the springs to pull them back in, away from that lip. worse comes to worse, just yank them off if you plan on replacing the brake stuff anyway... Murphy: if it jams, force it. if it breaks...it needed replacing anyway!
**Photobucket sucks**
[Re: mod5v]
#1160843
01/19/12 07:22 PM
01/19/12 07:22 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I sprayed pb blaster all in it cant get the adjuster to turn beat on it with hammer all kinds of rust fell dowthe drums are 11x3 all the way around do they make a 11x3 drum for front of 70 barracuda?
[Re: toplescuda]
#1160844
01/19/12 07:29 PM
01/19/12 07:29 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
we've removed them with a 3lb sledge. It is really hard ot hurt a drum.
If you snip the haed off the pins in the back, they will come off as an asembly
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: mod5v]
#1160845
01/19/12 07:31 PM
01/19/12 07:31 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
The bottom and sides pull out away from the backing plate just not the top center what the heck is at top center to keep it from prying away from backing plate what if i unbolted the wheel cyl.?
[Re: toplescuda]
#1160846
01/19/12 07:34 PM
01/19/12 07:34 PM
Challenger 1
Cincinnati, Ohio
Those things can be tough to get off sometimes. They do make a drum puller which helps a lot. Big sledge hammer has been used before by me to break them into peices. I think you should convert to disc brakes up front because front drums are gonna be hard to find I think. I converted my 71 from 4 wheel drum brakes, used spindles from a 73 E body that I used to own. I do still have the old 11" drums from the front but have never took them apart yet to check them out. What's crazy is my best new parts guy who I have known for a long time called me recently looking for those front 11" drums for one of his customers, he tells me he can't get them anymore?
[Re: Challenger 1]
#1160847
01/19/12 07:50 PM
01/19/12 07:50 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I dont want to swap to disc as the car is a number matching big block convertable want to keep it stock and save as much orignal stuff as possible
[Re: 70Coronet500Vert]
#1160850
01/19/12 07:57 PM
01/19/12 07:57 PM
Posts: 4,723 Florida
BDW
This is your best bet, once it's away from the backing plate, you can dig out the stuck parts.
[Re: Challenger 1]
#1160851
01/19/12 08:23 PM
01/19/12 08:23 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
What is at the very top that could be holding it???with the spindel nut off i can wiggle it up down and bottomand sides in and out from backing plate the shoes are on the sides so should be nothen top center i can move the hub up 1/4 inch or so just dont make any sence why sides move unless shoes not atached to backing plate any more from me prying
[Re: toplescuda]
#1160852
01/19/12 08:30 PM
01/19/12 08:30 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
The shoes are probably still attached, but they are on a spring and pin. So you can pull them out about an inch, and it is just compressing the pin. As far as whats holding it at the top, its probably the two heavy springs that keep them pulled in from the drum.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: toplescuda]
#1160854
01/19/12 08:40 PM
01/19/12 08:40 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Well least one of the pins not holding cause after smacking prying the lil disc thing fell out lol
[Re: toplescuda]
#1160855
01/19/12 08:47 PM
01/19/12 08:47 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
What if anything would happen if i unbolted the wheel cly? Its bolted from back side of backing plate corect? I cant remember now
[Re: toplescuda]
#1160857
01/19/12 08:55 PM
01/19/12 08:55 PM
hp383
State of Confusion
If you look in the picture, I think your trouble is with the "Anchor Pin" the one the heavy springs pull against.
[Re: bboogieart]
#1160860
01/19/12 09:33 PM
01/19/12 09:33 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Cant rotate it guiess the movement im getting is from colapse the short springs that hold shoes to back plate
[Re: Challenger 1]
#1160862
01/20/12 08:19 AM
01/20/12 08:19 AM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
Typically there is a ridge in the drum.Its about 1/4 inch.Thats where the drum dosent contact the shoes.They can be a bear to get off.You can grind the pin heads off in the backing plate and they usually come off.Ive had to pry some off.Use a few heavy screwdrivers and work them off.When I replace drums I usually cut the outer edge down a bit on the brake lathe.That way the ridge dosent catch like without the slight cut.Same thing when I turn drums.I cut that outer edge about .100 deeper than the drum is turned.Rocky
Chrysler Firepower
[Re: therocks]
#1160863
01/20/12 08:34 AM
01/20/12 08:34 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
I just went through this very thing on a rear drum on a '71 Mustang. What I did there, and have done before, is take a cold chisel and cut the heads off the "nails" for the shoe hold-down springs (look at the diagram posted earlier). That releases the shoes to pivot on the upper anchor. Worked for me every time.
[Re: dogdays]
#1160865
01/20/12 04:27 PM
01/20/12 04:27 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Il give it a try next decent day im off got a ? Thou... On the back the car has a sure grip ....going foward neither tire will roll but going backward the passenger tire will/did turn/roll backward is this cause of the sure grip not letting it turn from other hub stuck or is it just something in that drum only letting it turn one way?
[Re: radar]
#1160867
01/20/12 07:39 PM
01/20/12 07:39 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
BFH
No ...a LITTLER one ...
I have uNstuck a couple of these in a Dana 70 in the past couple of years. A short-handled 4? lb sledge has wurked-ferr-me.
[Re: Pyper70]
#1160870
01/23/12 09:58 AM
01/23/12 09:58 AM
70Coronet500Vert
St Charles MO
The flame torch is a good idea too. You may have a raised rust ring on the center hub and that may be keeping it form coming off too.
