Ladder bar bending the diagonal link,UPDATE #1160778
01/19/12 05:27 PM
01/19/12 05:27 PM
Cab_Burge Offline OP
I was under my Dister last week and seen that the diagonal link is bending in the middle I do drive it on the street as well as race it several times a year, any suggestions on how to fix it? Or what to do different on the rear suspension to fix it? I fianally got around to taking a picture of the bent diagonal link, it is bent up in the middle and to the right side of the car. The picture amy not show that but that is what it looks lie to me I couldn't find this post so I started another one Please look at this picture and tell me what you think is going on I di add some more information to the other psot on how I adjsuted the diagonal link the last time I put it in, I had to replace it when the ladder bar mounts broke off of the 8 3/4 because of one of the hiem joints in the original link was frozen up and broke off when I treid to adjust it putting it back in the car I had a truck Dana 60 cut down locally and there is around a 1/2 inch toe in on the new set up I'm taking the rear end out now and taking it to Dutchmen in Portland to have that corrected, I'll check the link for straighteness and call 1/4 Max(all thier parts) and ask them the way they want the link installed and adjusted and how to set the ladder bars up in the car as far as straightness
Re: Ladder bar suspension bending the diagonal link [Re: Cab_Burge] #1160779
01/19/12 05:49 PM
01/19/12 05:49 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Make one out of chrome moly Cab, that will cure it. poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Ladder bar suspension bending the diagonal link [Re: Cab_Burge] #1160780
01/19/12 06:01 PM
01/19/12 06:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what size i it? that is probably one of the reasons they tell you not to run one on a street car.
Re: Ladder bar suspension bending the diagonal link [Re: Quicktree] #1160781
01/19/12 06:22 PM
01/19/12 06:22 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I run one on my street car and never had that problem. Are the joints on the diag free without any binds ? Are the joints on the bars worn ?
6.50 @105.26
Re: Ladder bar suspension bending the diagonal link [Re: Cab_Burge] #1160782
01/19/12 09:31 PM
01/19/12 09:31 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
...NO more 'doughnuts' in the intersections with the ricers...
If you like drag racing, support your local track.
Re: Ladder bar suspension bending the diagonal link [Re: Cab_Burge] #1160783
01/19/12 09:41 PM
01/19/12 09:41 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So if its bending, its binding, or it is under severe compression, but that would be surprising as to why its not ever under tension and straightening the bend back out. Not the case of the mysterious bent front brake strut bar?
And CM would likely not resolve any of your issues enough to be a worthwhile change IMO.
Re: Ladder bar suspension bending the diagonal link [Re: jcc] #1160784
01/19/12 10:26 PM
01/19/12 10:26 PM
moparx Online content
moparx  Online Content
if the diagonal is bending, do the brackets on the rear or the front crossmember show any signs of stress ?
Re: Ladder bar suspension bending the diagonal link [Re: moparx] #1160785
01/19/12 11:07 PM
01/19/12 11:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run 1 1/8 CM and put a gusset on the rear ladder
bar bracket(its too far out in space for any side loading)
Re: Ladder bar suspension bending the diagonal link [Re: MR_P_BODY] #1160786
01/20/12 02:01 AM
01/20/12 02:01 AM
I made mine from 1" DOM - 1/4" thick wall because I heard of this happening.
Re: Ladder bar suspension bending the diagonal link [Re: ] #1160787
01/20/12 02:17 AM
01/20/12 02:17 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
steet cars need panhard bars.....if you make the daigonal link better then the ladder bar bracket is next, then the gusset, then........ I have built X braces for street cars.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ladder bar suspension bending the diagonal link [Re: bigtimeauto] #1160788
01/20/12 03:01 AM
01/20/12 03:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
can you post a pic?
Re: Ladder bar suspension bending the diagonal link [Re: rebel] #1160789
01/20/12 04:35 AM
01/20/12 04:35 AM
Mo.
racerx Offline
racerx  Offline
Mo.
can you post a pic?
^^what he said^^
Re: Ladder bar suspension bending the diagonal link [Re: racerx] #1160790
01/20/12 12:20 PM
01/20/12 12:20 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
can you post a pic?
^^what he said^^
A pic of a panhard bar?
Re: Ladder bar suspension bending the diagonal link [Re: bigtimeauto] #1160791
01/20/12 12:52 PM
01/20/12 12:52 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Either its super weak or something is binding
Re: Ladder bar suspension bending the diagonal link [Re: Cab_Burge] #1160792
01/20/12 01:36 PM
01/20/12 01:36 PM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
You might try adding on to your diagonal and make it an"X".
Re: Ladder bar suspension bending the diagonal link [Re: reknapp52] #1160793
01/20/12 01:40 PM
01/20/12 01:40 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Correct
Re: Ladder bar suspension bending the diagonal link [Re: bigtimeauto] #1160794
01/20/12 03:02 PM
01/20/12 03:02 PM
Mo.
racerx Offline
racerx  Offline
Mo.
can you post a pic?
^^what he said^^
No i was refereeing to the x brace.
Re: Ladder bar suspension bending the diagonal link [Re: MR_P_BODY] #1160795
01/20/12 03:38 PM
01/20/12 03:38 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
We went the same route as Mr. P after we bent our track locator. Solid as a rock now! The alston bar was only 7/8 diameter.
Re: Ladder bar bending the diagonal link. UPDATE [Re: WheelsUp73] #1160796
02/13/12 01:38 AM
02/13/12 01:38 AM
Here is a picture of the bent diagonal link, see my first post on top of this post for information update or the other new post I started earlier today on this problem 2nd attempt to attach picture
Re: Ladder bar bending the diagonal link. UPDATE [Re: Cab_Burge] #1160797
02/13/12 01:49 AM
02/13/12 01:49 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
no pic.
